| Thread Closed |
Enthalpy of Combustion for Magnesium |
Share Thread | Thread Tools |
| Nov15-04, 06:22 PM | #1 |
I placed some magnesium ribbon in HCl and measured the temperature change. How would i find the change in enthalpy per mole of magnesium in the following reaction:
Mg + 2HCl --> H2 +MgCl2 If i know the following information: change in temperature = 19C mass of ribbon = 0.5g volume of HCl = 100mL I can't use any known values (i.e. like the ones you'd find in a textbook). I must use the experimental values above. However, i can use specific heat capacity values, c, if i must. |
| Nov15-04, 08:56 PM | #2 |
[tex]Q=mc\Delta t[/tex]
where Q is the enthalpy change. You cannot just plug numbers into this formula though; remember that it applies to the entire system, and can be used in conjuction with [tex]\mbox{heat gain}=-\mbox{(heat loss)}[/tex] How is heat energy transfered in the reaction? (what gains, what loses?) |
| Nov15-04, 09:20 PM | #3 |
Did you perform that experiment in a "bomb calorimeter" (or a suitable improvised version thereof)? If not, the temperature change is meaningless, because an unknown amount of heat was dissipated to the surroundings.
| Nov15-04, 10:05 PM | #4 |
Admin
As Pack_rat2 alluded to, ideally one is doing this in an adiabatic system so that heat is not lost to the environment outside the reaction vessel (presumably test tube). One might have to correct of the mass of the reaction vessel as well if it is heated.
From the mass of HCl solution and temperature, one can determine the change in enthalpy of the solution. Then assuming that all the heat originated from the chemical reaction - one can determine the energy per unit mass or mole of Mg (the other known quantity). |
| Nov16-04, 06:37 AM | #5 |
But what will i use the specific heat capacity of HCl? I can't find that in my textbook.
| Sep23-08, 09:09 PM | #6 |
The Specific heat capacity of HCl (s) is 3.93 Jg-1C-1
| Sep24-08, 02:18 AM | #7 |
Admin
| Sep30-08, 10:31 PM | #8 |
Yea I would just use the specific heat capacity of water. My class just did this lab the other day. We used 0.5 M HCl and the teacher did some calculations on the board to show us that only about 0.2%(or somewhere around there) of the solution was HCl and the rest was water.
| Oct1-08, 02:23 AM | #9 |
Admin
| Thread Closed |
| Thread Tools | |
Similar Threads for: Enthalpy of Combustion for Magnesium
| [SOLVED] What is the enthalpy of combustion of magnesium? | Biology, Chemistry & Other Homework | 3 | ||
| Enthalpy of Combustion -- Alkanes | Biology, Chemistry & Other Homework | 2 | ||
| Enthalpy of Formation vs. Bond Enthalpy | Biology, Chemistry & Other Homework | 7 | ||
| Enthalpy of Dissolution vs. Enthalpy of Solution | Biology, Chemistry & Other Homework | 4 | ||
| Rusting of Magnesium | Chemistry | 3 | ||
