Can Magnet Wire Be Used to Turn Objects into Speakers?
  • Context: Undergrad
  • Thread starter Thread starter puuukeey
    Turning
The discussion revolves around the feasibility of using magnet wire to convert ordinary objects into speakers. Participants explore the technical challenges involved in creating a functional electromagnet that can handle audio signals and effectively vibrate the objects to produce sound.
  • One participant, Matt, describes his attempts to use magnet wire and a nail to create an electromagnet, noting issues with insulation melting and distorted sound quality.
  • Another participant suggests that the impedance is too low and recommends using more turns of finer wire, referencing the need to understand typical speaker configurations.
  • Matt acknowledges the suggestion and considers linking multiple reels of magnet wire to improve results.
  • Matt reports on wrapping a significant length of magnet wire around an iron bar and connecting it to two amplifiers, noting that clipping the amp produces more frequencies but distorts the original sound.
  • Another participant advises that the DC coil resistance should be around 3 to 4 ohms to prevent damage to the amplifier and suggests using a U-shaped bar for better magnetic circuit efficiency.
  • There is a suggestion to modify a standard speaker by cutting off the cone and attaching the voice coil to the object intended to be used as a speaker.
  • A link to an external resource is provided for further assistance on the topic.
Participants express various technical suggestions and experiences, but there is no consensus on the best approach to achieve the desired sound quality and functionality. Multiple competing views and methods are presented without resolution.
Participants mention specific technical parameters such as impedance, wire gauge, and magnetic circuit design, but the discussion remains open-ended with unresolved technical details and assumptions about the setup.
Individuals interested in audio engineering, DIY electronics, and experimental sound design may find this discussion relevant.
puuukeey
hi I found this forum on the net... . figured Id give it a try.
I'm a musician/audio guy working on a quirky project. my goal is to turn normal objects into speakers by painting them with some magnetic paint I found at my local art store. The other end of this, however, requires that I build a fixed electromagnet capable of handling an audio signal (presumably from an amp) and also capable of moving the object. (my first target is the base of a metal wash bin)
so far...
using magnet wire and a nail seems to yield sub par results. the insulation melts and smokes within 5 minutes and the magnet is rendered useless. the sound is also very distorted. it sounds as if there is a rectifier of some sort on the signal. it is also heavily weighted toward bass (which is ok and to be expected... hell its not like the bottom of a washboard is a paper cone)
whats the trick to converting electric audio signals to magnetic signals?
thanks for your time
matt
__________________________
Http://www.EstateSound.com
Your impedance is too low. Need more turns/finer wire. Take a speaker apart to find out typical combinations.
I would imagine the idea of turning ordinary objects into speakers is so that they can impart some of their own character to the sound, so isn't distortion desirable?
----NEAT I'll buy more magnet wire today. maybe link three reels up?
--------- yes, however, I've held a mic up to this monstrosity and (it will reacts to the magnetism before the sound.) and the waves are rectified. very strange. however I think its simple enough to deal with it. (just squeeze the whole wave above 0)
I'll post back when I get results
matt
out come for the record
well I've wrapped approximately 450 feet of 26 and 30 gauge magnet wire around an iron bar which is about 3/4" thick. connected to this bar is connected to two consecutive amps. (the alesis RA-100 which is "100 watts per channel into 4?, 75 watts per channel into 8?") both channels are clipping and the results are interesting.
clipping the amp produces more frequencies at one time which seems to make it louder however makes the original sound virtually undefinable. this frequencystack-to-loudness correlation seems to be in spite of the fact that the amp literally clips the wave form
Obviously I thank anyone and everyone for their help (as I have only knowledge of music and sound to repay) but if there is anyway I can get this darn thing loud/strong enough to reproduce sound well please post it. :)
Couple things.
You want the DC coil resistance to be somewhere around 3 to 4 ohms.
This is to keep the Amp from being damaged.
Look up on a wire table for ohms per foot for the wire you are using.
The magnetic circuit is also important.
A U shaped bar will be better than a straight bar.
The gap between the ends of the U and the moving surface should be as small as possible without hitting.
You could also try cutting the cone off of a standard speaker and gluing the voice coil to the surface you want to move.
Maybe you should have a look at this http://www.afrotechmods.com/cheap/hdspeakers/hdspeakers.htm
I hope it ll help
20K
10K
39K
