Arithmetic Sequence Series Problem
The discussion focuses on solving three arithmetic sequence problems. The first problem involves finding the value of x in the terms x+3, 3x-1, and 7x-2, resulting in x=5. The second problem calculates the sum of the first twenty-eight terms of an arithmetic series, given the sums of the first twelve and twenty-four terms, yielding a sum of -27. The third problem determines the first term (a) and common difference (d) for the terms t4 = -9 and t15 = -31, resulting in a = -3 and d = -2.
  • Understanding of arithmetic sequences and series
  • Familiarity with algebraic manipulation and solving equations
  • Knowledge of the formula for the nth term of an arithmetic sequence
  • Ability to apply the sum formula for arithmetic series
  • Study the derivation of the nth term formula for arithmetic sequences
  • Learn how to derive the sum formula for arithmetic series
  • Practice solving problems involving multiple terms in arithmetic sequences
  • Explore applications of arithmetic sequences in real-world scenarios
Students, educators, and anyone interested in mastering arithmetic sequences and series, particularly in algebra and mathematics education.
nobb
Hi. Please explain to me how to do these three problems:
1. The terms x+3, 3x-1, and 7x-2 are consecutive terms in an arithmetic sequence. Find x.
2. The sum of the first twenty-eight terms of an arithmetic series if the sum of the first twelve terms is -72 and the sum of the first twenty-four terms is 144.
3. Find a, d, and tn for this sequence: t4= -9 , t15 = -31
The terms in an arithmetic sequence always vary by a constant:
a+ r, a+ 2r, a+ 3r, etc so that subtracting and consecutive two terms gives r.
1. Here we must have (3x-1)- (x+1)= r= (7x-2)- (3x-1). Ignore the r and solve for x.
2. With an arithmetic sequence you can find the "average" of all numbers by averaging the first and last terms of the sequence. The sum of n terms is just n times that average.
In particular the average of the first 12 terms is (a1+ a12)/2 so the sum of the first 12 terms is 12(a1+ a12)/2= 6(a1+ a12)= -72.
Similarly, the sum of the first 24 terms is 12(a1+ a24)= 144.
Of course, if we take a1 as the first term and d as the common difference, a12= a1+ 11d and a24= a1+23d.
Putting those into the two equations for the sums gives you 2 equations in the two unkowns, d and a1. Once you know those, you can calculate a28= a1+ 27d and the sum is 28(a1+ a28[/sub)/2= 14(a1+ a28).
a1= a and ann= a+ (n-1)d so t4 (what I have called a4= a+ 3d= -9 and t15= a+ 14d= -31. Solve those two equations for a and d and then tn= a+ (n-1)d.
1. To find x, we can use the formula for the nth term of an arithmetic sequence, which is an = a1 + (n-1)d, where a1 is the first term and d is the common difference. In this case, we have a1 = x+3, a2 = 3x-1, and a3 = 7x-2. Plugging these values into the formula, we get:
a1 = x+3
a2 = (x+3) + d = 3x-1
a3 = (x+3) + 2d = 7x-2
Solving the first two equations for d and x, we get d = 2 and x = 5. Therefore, the terms are 8, 9, and 17 in an arithmetic sequence.
2. To find the sum of the first twenty-eight terms, we can use the sum formula for an arithmetic series, which is Sn = n/2(a1 + an), where n is the number of terms, a1 is the first term, and an is the last term. We are given the sum of the first twelve and first twenty-four terms, so we can set up the following equations:
12/2(a1 + a12) = -72
24/2(a1 + a24) = 144
Solving for a1 and a24, we get a1 = -9 and a24 = 15. Then, plugging these values into the sum formula, we get:
28/2(-9 + a28) = -72
a28 = -27
Therefore, the sum of the first twenty-eight terms is -27.
3. To find a, d, and tn, we can use the same formula for the nth term of an arithmetic sequence. We are given two terms, t4 = -9 and t15 = -31, so we can set up the following equations:
t4 = a + 3d = -9
t15 = a + 14d = -31
Solving for a and d, we get a = -3 and d = -2. Then, using the formula for tn, we can find the 4th and 15th terms:
t4 = -3 + 3(-2) = -9
t15 = -3 + 14(-2) = -31
  • · Replies 20 ·
