Largest IRG = 175.78125 MBytes"Calculating Largest IRG for 80% Data Tape
  • Thread starter nerdygazilio
  • Tags
    Data
In summary, the problem involves a 2400 foot magnetic tape with a recording density of 6400 Bpi and 100-byte data records. The memory buffer is 10,000 bytes and it is asked to find the largest IRG that will allow 80 percent of the tape to be data. By calculating the amount of data in 80 percent of the tape and using the recording density, it is determined that the total amount of data is 184,320,000 bytes. When converted to megabytes, this is equivalent to 175.78125 MBytes. Therefore, the largest IRG that will allow 80 percent of the tape to be data is 220, or 175.78125 MBytes.
nerdygazilio
Assume that a 2400 foot magnetic tape has recording density of 6400 Bpi. Data (logical) records are 100 bytes, and the memory buffer is 10,000 bytes. What is the largest IRG that will allow 80 percent of the tape to be data?
and
Tape length = 2400 ft = 2400×12 in=28800 inches
Recording density = 6400 bytes/in
Each record has 100 bytes = 64 inches
Memory buffer = 10,000 bytes
Largest IRG that allows 80% of tape to be data
Amount data = 80% of 2400 ft = 1920 ft consists of data.
Since each record has 100 bytes for 64 inches, then, 1 inch has 6400 bytes of data.
Total amount of data = 28800 inches × 6400 bytes = 184320000 bytes
= 184320000 bytes ÷ 220
= 175.78125 MBytes
This has not been answered. Is this what you are having trouble with?
If the density is 6400 bytes/in, then 6400 bytes = 1 in, and then 100 bytes should be much smaller than an inch.
Somehow your bad premise resulted in a correct statement.
True for 100% utilization (no IRG).
You have been pretty good at documenting your steps. Where does 220 come from?
= 175.78125 MBytes
How does 184,320,000/220 = 175,781,250? (I get the distinction you are using with "M", but still.../220?)
It is not two hundred and twenty(220)...it suppose to be 220 which gives the answer in megabytes same as multiplying 1024 by 1024..
1. What is the meaning of "Largest IRG" in relation to data tapes?
The Largest IRG (Inter Record Gap) refers to the maximum amount of space between two consecutive data records on a data tape. It is measured in bytes and is used to optimize the storage capacity and retrieval speed of the tape.
2. How is the Largest IRG calculated for a data tape?
The Largest IRG is calculated by taking into account the total capacity of the data tape and the percentage of data that will be stored on it. For example, in the case of a 175.78125 MBytes tape and 80% data storage, the Largest IRG would be 175.78125 x 0.80 = 140.625 MBytes.
3. Why is it important to calculate the Largest IRG for a data tape?
Calculating the Largest IRG allows for efficient use of the data tape's storage capacity. If the IRG is too small, there may not be enough space for the data to be stored, resulting in wasted storage space. If the IRG is too large, it may decrease the tape's retrieval speed.
4. Is there a standard or recommended value for the Largest IRG?
There is no universally accepted standard or recommended value for the Largest IRG. It varies depending on the type of data being stored and the specific requirements of the data storage system. It is typically determined through testing and optimization for each individual case.
5. Can the Largest IRG be adjusted after the data tape has been formatted?
No, the Largest IRG is determined during the formatting process of the data tape and cannot be changed afterwards. If the IRG needs to be adjusted, the tape would need to be reformatted with the new IRG value.
