How Does Calculating the Limit Help Find g in Advanced Mathematics?
  • Context: Graduate
  • Thread starter Thread starter JasonRox
    Definition Limit
This discussion focuses on finding the value of g in the context of limits in advanced mathematics, specifically using the function x^3. The inequalities |x^3-a^3| PREREQUISITES
  • Understanding of limits in calculus
  • Familiarity with the difference of cubes formula
  • Knowledge of the triangle inequality
  • Basic algebraic manipulation skills
  • Study the formal definition of limits in calculus
  • Learn about the difference of cubes and its applications
  • Explore the triangle inequality and its implications in mathematical proofs
  • Practice solving inequalities involving limits and continuity
Students and educators in advanced mathematics, particularly those focusing on calculus and limit theory, as well as anyone interested in deepening their understanding of mathematical proofs and inequalities.
JasonRox
How do I find g?
It's so confusing.
I'm trying to learn this on my own, so bare with me.
I'm going with an example I know the answer to, and maybe someone can work with me here. I'll ask questions through the solution.
We will do x^3 since that is complicated enough, but I understand the steps, just not the logic to moving on to the next step.
[tex]|x^3-a^3|<e[/tex]
[tex]0<|x-a|<g[/tex]
Find a value for g that satisfies the above.
[tex]|x^3-a^3|=|x-a||x^2+ax+a^2|[/tex]
[tex]|x^2+ax+a^2|<=|x|^2+|a||x|+|a|^2[/tex]
Note: [tex]|x|-|a|<=|x-a|<1[/tex]
If you don't understand why one is chosen maybe this isn't for you. In case you forgot, we take 1 because that guarantees that the difference won't be too big.
[tex]|x|<1+|a|[/tex]
Take the above and you get...
[tex](1+|a|)^2+|a|(1+|a|)+|a|^2<br /> <br /> WARNING: This is in the works. I will be back to complete it.[/tex]
You'd be better using that |a|< |x| +g
or better yet, assuming that g is chosen such that |a|<2|x|, since if some g works, a smaller g has to work too, so there's no harm in placing a maximal size on g that helps eliminate a (assuming x is not zero. if x is zero it's quite easy)
The precise definition of a limit is a mathematical concept that describes the behavior of a function as the input approaches a certain value. In other words, it determines what value a function is approaching as the input gets closer and closer to a specific value. To find the limit, we use a specific notation: lim f(x) = L as x approaches a, which means that the limit of f(x) is L as x gets closer and closer to a.
To find g in the given problem, we need to find a value for g that satisfies the inequalities |x^3-a^3|<e and 0<|x-a|<g. This means that the difference between x^3 and a^3 must be smaller than e, and the difference between x and a must be smaller than g.
To solve for g, we can start by simplifying the expression |x^3-a^3|. Using the formula for the difference of cubes, we can rewrite it as |x-a||x^2+ax+a^2|. Now, we want to make this expression smaller than e, so we can set up the inequality |x^2+ax+a^2|<=e.
Next, we can use the triangle inequality to simplify the expression further. This states that |x+y|<=|x|+|y| for any numbers x and y. In our case, we can rewrite |x^2+ax+a^2| as |x|^2+|a||x|+|a|^2.
Now, we can use the given inequality 0<|x-a|<g to solve for g. We know that |x|-|a|<=|x-a|<1, so we can substitute |x|-|a| for |x-a| in the inequality |x|^2+|a||x|+|a|^2<=e. This gives us (|x|-|a|)^2+|a|(|x|-|a|)+|a|^2<=e.
To make this expression even smaller, we can choose a value for |x| that is close to |a|. In fact, if we choose |x|<1+|a|, we can guarantee that the expression will be smaller than e. This is because (1+|a|)^2+|a|(1+|a|)+|a|^2 is
  • · Replies 53 ·
