How emission theory was disproved by de sitter binary star experiment?
The forum discussion centers on the disproval of Ritz's emission hypothesis through the de Sitter binary star experiment. The hypothesis suggests that light emitted from moving objects would travel at speeds of (c + v) or (c - v), leading to potential discrepancies in the observed positions of stars. However, experiments using terrestrial sources, such as those by Alvaeger et al. and Filipas and Fox, have consistently measured the speed of light as constant (c), thereby refuting the emission theory. Notably, the results from these experiments demonstrate no significant variation in light speed, confirming the principles of Special Relativity.
  • Understanding of Special Relativity principles
  • Familiarity with light speed measurements and experimental physics
  • Knowledge of gamma ray behavior and particle physics
  • Awareness of the significance of optical extinction in experiments
  • Research the implications of Special Relativity on light speed, focusing on "Einstein's theory of relativity."
  • Study the experimental methodologies used in "Alvaeger F.J.M. Farley et al.'s 1964 light speed experiment."
  • Explore the concept of "optical extinction" and its relevance in high-energy physics experiments.
  • Investigate the operation and findings of "FLASH, a free-electron laser," to understand its impact on light speed measurements.
This discussion is beneficial for physicists, students of relativity, and anyone interested in the experimental validation of light speed and the principles of Special Relativity.
techysafi
Actually I was studying on 2nd postulate of special relativity. There I saw Ritz's emission hypotheses says for an object moving directly towards (or away from) the observer at v metres per second, this light would then be expected to still be traveling at (c + v) or (c − v) metres.
Now let's imagine an orbiter (star) trows a photon from A, another from B, another from C and another from D. Also imagine that the velocity of the photon of A is (c + v) and of C is (c-v). If this happens we would get an weird picture of the orbiter because the the distance from the orbiter to the observer is sufficient enough then the faster photon (A) would reach to the observer faster than photon of C THOUGH PHOTON of C WAS RELEASED FIRST THEN D THEN A. (assuming the orbit is a->b->c->d->a) And this means we would often see the star at random places or at multiple position at a same time. but william de sitter didn't find any such thing...Am I right? If wrong then where I am wrong?
You see I'm noob so a nooby friendly answer will help me more :)
You need terrestrial experiments to address the extinction question, not astronomical ones.
See the appropriate section in the paper referenced by the FAQ
https://www.physicsforums.com/showthread.php?t=229034
stickied as the top thread in the relativity forum.
Experiments Using Terrestrial Sources
Alvaeger F.J.M. Farley, J. Kjellman and I Wallin, Physics Letters 12, 260 (1964). Arkiv foer Fysik, Vol 31, pg 145 (1965).
Measured the speed of gamma rays from the decay of fast π0 (~0.99975 c) to be c with a resolution of 400 parts per million. Optical extinction is not a problem for such high-energy gamma rays. The speed of the π0 is not measured, but is assumed to be similar to that measured for π+ and π−.
Sadeh, Phys. Rev. Lett. 10 no. 7 (1963), pg 271.
Measured the speed of the gammas emitted from e+e− annihilation (with center of mass v/c ~0.5) to be c within 10%.
This experiment was criticized in Lo Savio, Phys. Lett. A, 1988, Vol 133, pg 176. It is certainly true that at the instant of annihilation the e+ need not be traveling in the same direction it had initially, or have the same speed (most annihilations occur at very low energy as the positrons stop). This experiment is inconclusive at best.
Babcock and Bergmann, Journal Opt. Soc. Amer. Vol. 54, pg 147 (1964).
This repeat of Kantor's experiment in vacuum shows no significant variation in the speed of light affected by moving glass plates. Optical Extinction is not a problem. k < 0.02.
Filipas and Fox, Phys. Rev. 135 no. 4B (1964), pg B1071.
Measured the speed of gamma rays from the decay of fast π0 (~0.2 c) in an experiment specifically designed to avoid extinction effects. Their results are in complete disagreement with the assumption c+v, and are consistent with SR. k < 0.5 with a confidence level of 99.9%.
Beckmann and Mandics, “Test of the Constancy of the Velocity of Electromagnetic Radiation in High Vacuum”, Radio Science, 69D, no. 4, pg 623 (1965).
A direct experiment with coherent light reflected from a moving mirror was performed in vacuum better than 10−6 torr. Its result is consistent with the constant velocity of light. This experiment is notable because Beckmann was a perennial critic of SR. Optical Extinction is not a problem.
Operation of FLASH, a free-electron laser, http://vuv-fel.desy.de/.
A free-electron laser generates highly collimated X-rays parallel to the relativistic electron beam that is their source. If the region that generates the X-rays is L meters long, and the speed of light emitted from the moving electrons is c+kv (here v is essentially c), then at the downstream end of that region the minimum pulse width is k(L/c)/(1+k), because light emitted at the beginning arrives before light emitted at the downstream end. For FLASH, L=30 meters, v=0.9999997 c (700 MeV), and the observed X-ray pulse width is as short as 25 fs. This puts an upper limit on k of 2.5×10−7. Optical extinction is not present, as the entire process occurs in very high vacuum.
  • · Replies 26 ·
  • · Replies 0 ·
