Charge in the battery after charging for a certain time
by nobrainer612
Tags: battery, battery capacity, charge, charging, ideal battery
nobrainer612
nobrainer612 is offline
#1
Sep15-11, 11:11 AM
P: 26
An ideal 9V battery is connected to a resistive divider consisting of a 330 Ohm and a 600Ohm resistor. A 1.5V rechargeable battery in series with a 1.5k Ohm resistor is connected in parallel with the 330 Ohm resistor. The battery has a capacity of 1200mAh and is half charged. How much charge does it hold after 10 hours?
2. Relevant equations
V=R*i
battery charging time = capacity of the battery / charging current power output of the charger:
hr = mAh / mA
AAA AA C D sizes rechargeable batteries:
hours ( charging time ) equals to 12 x Ahr OR 12/100 x mAh ( 12/100 x mAh = hrs )
Power = V*i
3. The attempt at a solution
I tried to find the current going to the 1.5k Ohm dc source. I first combined the R1 and Ri2(internal) as parallel.
1/Req = 1/330 + 1/1500
Req= 270.5
Then I combined R1 to Req since they are in series:
270.5 + 600 = 870.5 Ohm
The the total Req is 870.5 Ohm
Then I tried to find the current passing through the total Req:
V=Ri
i=9V/870.5
i=0.01033
Then I will use the equation:
= 1200mAH/0.01033
= 116166 .. wow
At this point I am totally confused. Since this is such a large number, I feel like I am doing it wrong.
Any help is appreciated.
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Register to reply
Related Discussions
Super Capacitor Banks, Instant Charging, Inversion, Charging Battery Banks, Capacitor Electrical Engineering 6
Charge Flown Through Battery In Charging Capacitor Introductory Physics Homework 20
Battery Charging Electrical Engineering 3
how to change the charging time (battery) General Physics 4
minimize charging time of a battery Electrical Engineering 3
