Calculating Frequency of a Traveling Wave on a String with Given Parameters
  • Thread starter Thread starter nazarip
    Wave
The discussion revolves around calculating the frequency of a traveling wave on a string, given its linear mass density and wave speed. The original poster presents a specific equation for the wave's displacement and expresses uncertainty about how to proceed with the calculations.
  • Participants discuss the relationship between wave speed, frequency, and wavelength, referencing relevant equations. There is confusion regarding the interpretation of parameters in the wave equation, particularly the values of wave number and angular frequency.
Some participants have provided clarifications about the parameters in the wave equation, particularly correcting the interpretation of angular frequency. The discussion is ongoing, with participants exploring different interpretations and seeking further guidance.
There is a noted lack of clarity regarding the values of wave number and angular frequency, as well as the implications of negative frequency values. The original poster expresses a need for direction without having a complete understanding of the problem setup.
nazarip
A string has a linear mass density of 3.4 g/m. When a sinusoidal wave is created on the string with a speed of 32.8 cm/s the displacement of the particles on the string at x=13.3 cm varies with time according to the following equation: y=4.4sin[1.1-3.3 t] cm. Find the frequency.
Well, I am stuck on this question and need a kick in the right direction...
v=f*lambda
angular velocity=2*3.14*f=wave#*velocity
I really don't have a clue as to where to begin...
The equation of a traveling wave moving in the positive x direction is:
[tex]y = A \sin(kx - \omega t)[/tex]
where
[itex]k[/itex] is the wave number
[itex]\omega[/itex] is the angular frequency
[itex]A[/itex] is the amplitude.
the equation I am given doesn't have an x variable so am I to assume k= 1.1? or w=-3.3? And if w=-3.3 then the frequency would be a negative number? is that possible?
You're given x=13.3 cm.
Also, w is not -3.3, but 3.3.
oh ok, thanks for the help.
  • · Replies 16 ·
