New Reply
Using the sun to heat a liquid
Share Thread Thread Tools
Sep17-11, 11:17 AM   #1
Is it possible to use the heat of the sun to heat a liquid (arbitrary liquid) to a temperature that is hotter than the sun, say 5 times hotter?
2. Relevant equations
Concepts in thermal equilibrium
3. The attempt at a solution
My answer is no since you can't get more heat from what is not there. On the other hand, if you can focus the energy from the sun then this is where I am unsure.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep17-11, 11:27 AM   #2
No, this is not possible, because heating something to be hotter than the source, requires a decrease in entropy (don't have the equation relating to this with me, one that relates S to T), which according to T-D is virtually impossible.
New Reply
Tags
equilbruim, thermal
Thread Tools
Similar Threads for: Using the sun to heat a liquid
Thread Forum Replies
Experiment to find specific heat of a liquid Engineering, Comp Sci, & Technology Homework 4
Heat transfer from gas to liquid during compression Mechanical Engineering 4
which liquid have low specific heat capacity Introductory Physics Homework 3
heat transfer for flow that it has 2 phase (liquid and gas) Mechanical Engineering 0
liquid freeze => give heat? Introductory Physics Homework 2
