Complex Variables and Integration
The discussion revolves around evaluating an integral using techniques from complex variables, specifically focusing on the integral from 0 to infinity of [x^m/(x^2 + 1)^2] for values of m between 1 and 3.
  • Participants discuss the selection of a contour for integration, considering branch points and the implications of the non-integer value of m. Questions arise regarding the treatment of singularities at z=i and z=-i, and how they affect the contour choice.
The conversation is ongoing, with participants clarifying the contour's path and its relation to the singularities. There is an emphasis on understanding the bookkeeping involved in the contour integration process, but no consensus has been reached on the final approach.
Participants are navigating the complexities of contour integration in the context of branch cuts and singularities, with specific attention to the behavior of the integral as it approaches the origin and infinity.
Ed Quanta
How do I solve the following integral using complex variable techniques
The integral from 0 to infinity of [x^m/(x^2 + 1)^2]; 1<m<3
You will have to select a contour judiciously. Since m is not generally an integer then z = 0 is a branch point. Choose the branch to extend from 0 to infinity along the positive real axis. For your contour, one part will extend from infinity along the positive real axis and loop arbitrarily close to the origin then continue along the positive real axis paying close attention to the fact that [itex]z = R e^{2 \pi i}[/itex] along that portion of the contour. The rest of your contour circles around from [itex]\infty e^{0i}[/itex] to [itex]\infty e^{2\pi i}[/itex].
Now just apply the Cauchy Integral Theorem! You'll pick up a residue from the small loop around the origin and the two linear segments have different phases and their sum is proportional to the integral you want to evaluate.
What about the singularities at z=i and at z=-i?
Do I make my contour so that these two points are not included?
Using the contour I described, those singularities are included. You have to be aware of what is inside and outside the contour and it becomes a simple matter of proper bookkeeping!
So let me get this straight, we have a contour that extends from infinity along the positive real axis, loop around as it comes close to the origin, and then what does it do on the negative real axis? Sorry, just trying to get this picture in my head.
Okay - step by step: Start at infinity along the positive real axis and go toward the origin. Loop around the origin (tiny loop!) and go back out to infinity (on the [itex]e^{2\pi i}[/itex] side!) then close your loop with a big circle at infinity. We're choosing [itex]z = R e^{2\pi i}[/itex] to be the branch cut.
  • · Replies 22 ·
  • · Replies 29 ·
