New Reply
Given a random number from 0-3, return a random number from 0-6
Share Thread Thread Tools
Sep18-11, 01:38 PM   #1
This is actually for a program, but the challenging part is really the math. So you're given a number 0, 1, 2, or 3 and the probability of getting each is the same. Now given this random number, I need to output a number 0, 1, 2, 3, 4, 5, or 6 but the probability of getting each number needs to be the same.
Can anyone point me in the right direction?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Sep18-11, 02:41 PM   #2
Quote by gsingh2011 View Post
You need to specify how the outcome of the first round will affect the second round. Otherwise you just have two independent outcomes a,b. Then the probability of any pair is 1/28.
Sep18-11, 03:38 PM   #3
Quote by SW VandeCarr View Post
Well the relationship is that after being given this random number from 0-3, you need to perform mathematical operations (functions such as floor and ceiling are allowed) to arrive at a new number from 0-6. Now if you performed these same steps for the random input number many times, you would end up with the numbers from 0-6 an approximately equal number of times (probability of getting each number is the same). Does that clarify the problem?
Sep18-11, 07:38 PM   #4
Quote by MisterX View Post
These functions are for use with non-integer numbers.
I thought division might be involved, resulting in non-integers.
However, if the output needn't be random, but only uniform
What's the difference? I thought if something was random, the probability for each result would be the same (uniform).
You could do something like generate a second 0-3 integer pseudorandomly and determine the 0-6 integer using the two integers. You could have the program do something somewhat similiar if you are able to get two 0-3 random integers.
I'll try it out, see if I can come up with anything.
If anyone else has any other ideas, please share them.
EDIT: Seems like the person above me deleted their post, making me seem crazy.
Sep18-11, 08:07 PM   #5
You can randomize 0,1,2,3 twice to randomly express any number from 0 through 15 in base 4. Keep doing that till you get a number in the desired range. This procedure is not guaranteed to terminate, but each of 0 through 6 have the same probability of being chosen. Just a thought.
Sep18-11, 08:14 PM   #6
Suppose x is a random integer from 0-3.
Suppose the program performs something such as floor(f(x)). Where f is a function by the mathematical definition of a function.
We may get from this, a maximum of four unique outcomes, which is what we started with (four values of x). But we may actually end up with less.
New Reply
Thread Tools
Similar Threads for: Given a random number from 0-3, return a random number from 0-6
Thread Forum Replies
MATLAB - random allocation of random number Engineering, Comp Sci, & Technology Homework 1
Sum of random number of random variables Set Theory, Logic, Probability, Statistics 8
Expectation and variance of a random number of random variables Calculus & Beyond Homework 3
Random Number Precalculus Mathematics Homework 2
Random Number Set Theory, Logic, Probability, Statistics 0
