New Reply
Project: Using 100% of an Atoms energy
Share Thread Thread Tools
Sep18-11, 10:20 PM   #1
I AM TRYING TO PROGRESS IN THIS PROJECT AND ONLY SEE ONE DIRECTION PLEASE IF YOU HAVE ANY KNOWLEDGE OR THEORY OF THIS PLEASE INCLUDE IT!!!!
Edit: personal information deleted
I’m a sophomore at High school in Arizona.
Although I’m most likely not as smart as most people on this forum, I’m trying to discover something that may change our world forever.
My idea hails from the Atom, and exactly how much power one atom consists compared to how much of it we are actually using.
Please correct me if I’m wrong, if we were to convert 100% of the matter in a tree into energy could we power the entire world for over 10 years( referring to the formula (Energy = Mass x [186,000 miles/ second])?
Now if you were to split an atom in the middle of a set amount of atoms, and surround it with EM radiation would it cancel out the radiation released from the atoms that were reacting with the one atom that was split, leaving the energy released contained until the amount of energy released is gone? (Suggesting that the string of radiation cancel each other out)
Iron for an example say it was put into an object like an iron ball, and put it in the middle of Uranium radiation and then split an atom in the iron ball, could that keep all of the energy in atoms of the ball contained in the medium between the Uranium radiation and the atomic radiation of the ball?
Now if we tried to use that energy to run a car, the car would run for almost an unlimited amount of time because of the extremely large amount of energy given off, but0 something like that is only a question that is to be solved from what has already been discovered.
Um all of this information comes from research that I have done, please correct me if I’m wrong I’m planning on making this a learning experience and I’m hoping that this project will prevail.
Please remember I am only 16 years old, I’m just simply trying to expand my knowledge so I would appreciate only positive input as I’m trying my best to be successful in my lifetime.
P.S. Im going to be adding notes frequently.
NOTES:
What if this process was used but instead surrounding water with uranium and EM radiation, and using the Nuclear Fusion process to make water into fuel(this is basically just makes sure that the energy coming out of the water molecules is used at its 100% capacity).
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Sep18-11, 10:24 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Yes, IF we could use 100% of an Atoms energy, then we have nearly limitless power!!
The problem is, that we can't harness that energy. We have no way of getting it out of the atom.
We can't even get fusion to work out.
Sep18-11, 10:43 PM   #3
Quote by micromass View Post
True, but say we gave this test a very large scale to perform it on like in space, we could try to expand the energy and cancle it out with another type of radiation, that would stop the energy from moving leaving it isolated which would only leave one question to be awnser how would we make that energy availible to us as it is in space and not on earth, well i believe if i continue this research than it will be discovered. :)
Sep18-11, 10:46 PM   #4
Recognitions:
Quote by 16 years old View Post
OK:
1) how will you transform atoms into energy??
2) how will you build a giant reactor in space??
3) How will you harness the energy and put it to use??
Sep18-11, 10:59 PM   #5
OK:
1) By splitting the atom and releasing all of its energy.
2) I have limited resources but if my theory proves correct, i will have many supporters that will help me to build it.
3) Using multiple layers of energy and objects to keep the energy from flowing putting it to use though just lies in my research
Sep18-11, 11:07 PM   #6
Recognitions:
That won't free 100% of the atoms energy! Not even close.
Having many supporters won't help. You have many difficulties to conquer!
Assume that you could prevent energy from flowing away. How will you use the energy?? Having energy is nothing: the sun has energy enough! But how to use it?
Sep18-11, 11:19 PM   #7
Recognitions:
INTJ
Introverted Intuitive Thinking Judging
67 50 88 44
Sep18-11, 11:29 PM   #8
Very true, but if an atom is split, and the energy flows from it what will happen to the atom? will it remain split and continue to let out energy until it has none left?
And yes but i will work for years if i have to on this project to get rid of thoes many difficulties.
would it work if i could cause a chain reaction between the energy and the motherboard using metal wires?
Sep19-11, 12:07 AM   #9
Recognitions:
It doesn't work this way. I suggest you read up on your physics and chemistry.
I have no idea what you're talking about here...
Sep19-11, 12:07 AM   #10
Community 2012
Recognitions:
It's nice that you have an interest in physics, but your understanding is way way off. Hit the books and learn how physics actually works, then you'll find out why what you said makes 0 sense.
Sep19-11, 02:21 AM   #11
Ok, I will ha just figured out the awnser to my question as you posted this.. im learning at a fast paste.. But please awnser just a few questions for me? Just need it for future research.
1) What happens when 2 different types of radiation intersect?
2) How can energy be transfered?
3) Is it possible to store radiation? and how?
4) Is their any online books for this? can't afford the actual books right now.
And if you could kindly write up your opinion of what physics is I would love to get an idea from someone that has their masters in physics :)
Sep19-11, 04:01 AM   #12
Community 2012
Recognitions:
A fast pace you mean....
You should definitely just start studying using a public library and its resources if your school library doesn't help. Wikipedia is also helpful at times.
Your questions are pretty hard to answer because you don't have a proper understanding of 'radiation'. Radiation can be anything from gamma rays (photons) to alpha particles (fully ionized helium) to beta particles (electron/positron). In one case (gamma rays), you can't contain them while something like alpha particles are easy to contain. In either case this has nothing to do with making your idea work.
Another thing to note is that energy is not released like air coming out of a popped balloon when an atom fissions. The energy released during a fission reaction is the actual kinetic energy the 'daughter products' have when they go flying off after the reaction. It's not a substance that is freed upon fission.
Sep19-11, 08:19 PM   #13
Quote by Pengwuino View Post
Thank you :) i will start studying, and im planning on working on this for a long period of time (4-10 years if possible) so please subscribe to this topic cause i will be back for questions and results :).
Sep19-11, 08:20 PM   #14
Oops! please excuse my grammatical error, english isn't my forte..
Sep19-11, 09:44 PM   #15
Is it even possible to know what is 100% of an atom's energy? Even if we knew, would it take more than 100% of that atom's energy to obtain all of its energy?
Sep19-11, 09:47 PM   #16
in 10 years you'd be about halfway through your phd. it is barely there that you will actually start working
Sep19-11, 10:22 PM   #17
Community 2012
Recognitions:
Quote by DrClapeyron View Post
An atom at rest is given by E=mc^2.
You can't attain even close to 100% of an atom. With even the smallest atoms, you can induce fusion, but the energy harnessed is still a very small % of the entire energy of the atoms. Even after a fusion reaction, you're still left with atoms with almost the same mass. However, that small change in mass for us is still a tremendous amount of energy compared to something like a chemical reaction.
What you COULD do is smash particles together with such tremendous energy that they produce the whole world of particle physics and you could say the mass of those particles are converted into energy. However, at such extreme energies, particles are actually produced and the whole E=mc^2 thing kinda gets thrown in reverse; energy is converted into particles with mass! At that point, you're no longer talking about getting mass to convert into energy; you're getting energy to convert into mass.
New Reply
Thread Tools
Similar Threads for: Project: Using 100% of an Atoms energy
Thread Forum Replies
energy of a star's atoms Astrophysics 3
energy of hydrogen atoms Quantum Physics 11
repulsion energy of two atoms Advanced Physics Homework 0
Atoms = Energy General Physics 4
Needing images of atoms for project Atomic, Solid State, Comp. Physics 3
