Calculate how long it will take for the ice to melt?
  • Thread starter Thread starter klilly
    Ice
The calculation of how long it will take for ice to melt in a chilly bin made of styrofoam involves thermal conductivity principles. Given a wall thickness of 5.90 cm, an area of 0.700 m², and an outside temperature of 28.0 °C, the power transferred into the bin is calculated using the formula P = kA(ΔT/Δx). With a thermal conductivity (k) of 0.0100 J s–1 m–1 °C–1, the power is determined to be 3.322 W. The total energy required to melt 2.00 kg of ice at 0.00 °C is 6.7 x 10^5 J, leading to a total melting time of 56 hours.
  • Understanding of thermal conductivity and heat transfer principles
  • Familiarity with the equation for power transfer in thermal conduction
  • Knowledge of latent heat of fusion for water (Lf)
  • Basic algebra for solving equations involving power, energy, and time
  • Study the laws of thermal conduction in detail
  • Learn about the properties of different materials and their thermal conductivities
  • Explore the concept of latent heat and its applications in phase changes
  • Investigate practical applications of heat transfer in insulation materials
Students studying thermodynamics, physics enthusiasts, and anyone interested in practical applications of heat transfer principles in everyday scenarios.
klilly
Calculate how long it will take for the ice to melt??
A chilly bin has walls 5.90 cm thick and the total area of the walls is 0.700 m2. The chilly bin is loaded with 2.00 kg of ice at 0.00 °C and stood on a rack so that its entire surface is in contact with the air. The temperature on the outside of the chilly bin is 28.0 °C. If the chilly bin is made of styrofoam (kstyrofoam = 0.0100 J s–1 m–1 °C–1), how many hours will it take to melt all of the ice?
(Note: Lfwater = 3.35 × 105 J kg–1)
I was given (L (water) x m (water))/ kA(Change in T/Change in thickness)
But it didnt work out right
Answer is: 56 hours
I have no idea how to get to this :(
law of thermal conduction says
[tex]\mathcal{P}=kA\;\frac{\Delta T}{\Delta x}[/tex]
where P is the power transferred, k is thermal conductivity, A is the area of the surface through which energy will flow, [itex]\frac{\Delta T}{\Delta x}[/itex] is temperature gradient.
[itex]\Delta T[/itex] is the temperature difference between inner and outer surface,
[itex]\Delta x[/itex] is the thickness of the bin.
now we have been given , for chilly bin (made out of styrofoam)
k= 0.0100 J s-1 m-1 °C-1
A=0.700 m2
delta T=28-0=28 °C
delta x=5.92 x 10-2 m
using this you can find the power which transfers from the outside to inside where ice is
stored. P= 3.322 J s-1=3.322 W
now amount of energy required to melt m kg of ice is
[tex]Q=m_{ice}L_f[/tex]
mice=2 kg ; Lf=3.35 × 105 J kg-1
so we get Q= 6.7 x 105 J
if t is the time required to melt all ice then Q must be equal to P x t . solve for t. its 56 hrs
  • · Replies 17 ·
