Solve PDE Method of Characteristics help
  • Thread starter Thread starter lackrange
    Method Pde
The discussion focuses on solving the partial differential equation (PDE) using the Method of Characteristics for the equation xu_x + 2yu_y + u_z = 3u with the initial condition u(x,y,0) = g(x,y). The user successfully derived the characteristic equations: du/ds = 3u, dx/ds = x, dy/ds = 2y, and dz/ds = 1, leading to expressions for u, x, y, and z in terms of the parameter s. The solution involves expressing the characteristics in terms of x, y, and z, ultimately defining new variables to simplify the problem.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the Method of Characteristics
  • Knowledge of exponential functions and logarithms
  • Basic skills in manipulating equations and variables
  • Study the derivation of characteristic curves in three-variable PDEs
  • Learn about the implications of using new variables in PDE solutions
  • Explore examples of the Method of Characteristics applied to different PDEs
  • Investigate the role of initial conditions in solving PDEs
Mathematicians, physics students, and engineers interested in solving complex partial differential equations, particularly those utilizing the Method of Characteristics.
lackrange
The problem: Solve for u(x,y,z) such that
[tex]xu_x+2yu_y+u_z=3u\; \;\;\;\;u(x,y,0)=g(x,y)[/tex]
So I write
[itex]\frac{du}{ds}=3u \implies \frac{dx}{ds}=x,\; \frac{dy}{ds}=2y\;\frac{dz}{ds}=1 .[/itex]
Thus [tex]u=u_0e^{3s},\;\;x=x_0e^{s}\;\;y=y_0e^{2s}\;\;z=s+z_0[/tex]
but from here I can't figure out what to do, there are several ways I can write s...I have only done the method of characteristics before with two variables, and those are pretty much the only examples I can find. Can someone help please?
So I write
If you have done the method of characteristiced with two variables it pretty much generalizes to three variables directly- write out the characteristics in terms of x, y, and z and use those to define new variables.
If [itex]x= x_0e^s[/itex] and [itex]y= y_0e^{2s}[/itex], you have [itex]s= ln(x/x_0)= (1/2)ln(y/y_0)[/itex] so that ln(x/x_0)- ln(y^{1/2}/y_0^{1/2})= ln((y_0^{1/2}/x_0)(x/y^{1/2}= 0 which then gives [itex]x/y^{1/2}= constant[/itex]. Each curve with different constant is a characteristic. With [itex]z= s+ z_0[/itex] that gives also [itex]s= z-z_0= ln(x/x_0)[/itex], have [itex]x/x_0= e^{z-z_0}= e^{-z_0}e^z[/itex] so [itex]x= (constant)e^z[/itex] or [itex]xe^{-z}= constant[/itex]. Putting [itex]s= z-z_0= ln(y^{1/2}/y_0^{1/2})[/itex], we get [itex]y^{1/2}e^{-z}= constant[/itex].
We want to use those "characteristics" or "characteristic curves" as axes: let [itex]u= x/y^{1/2}[/itex], [itex]v= xe^{-z}[/itex], and [itex]w= y^{1/2}e^{z}[/itex].
