Problem about adiabatic expansion of gases
The discussion revolves around the adiabatic expansion of 1 mol of hydrogen gas, focusing on calculating heat, internal energy, and work during the process. Participants are examining the implications of the first law of thermodynamics in the context of this specific gas behavior.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate the final temperature after an adiabatic expansion and subsequently determines heat, internal energy, and work. Some participants question the correctness of the equations used and the assumptions made regarding the signs of work and internal energy.
Participants are actively engaging in clarifying the calculations and addressing potential errors in reasoning. There is a recognition of the need to correctly apply the first law of thermodynamics, and some guidance has been offered regarding the definitions of work and internal energy changes.
There are discussions about the approximations used for specific heat capacities and the importance of correctly applying the equations for internal energy and work in the context of adiabatic processes.
Rujano
Hello everyone. I would like to know if I did this correctly.
Calculate the heat, internal energy and work of 1 mol of hydrogen, which undergoes a reversible adiabatic expansion from a volume of 5.25 m^3 at 300 K to a volume of 25.5 m^3
The first thing that I have to do is to find the final temperature using the following equation:
(Vf/Vi)^1-y * Ti = Tf
y = gamma
y = Cp/Cv
Because it's HYDROGEN (diatomic gas):
y = 7/2/5/2 = 1.4
(25.5 m^3/5.25 m^3)^1.4 * 300 K = Tf
Tf = 2741.9 K
so...
a) Heat
becuase it's an ADIABATIC expansion
Q = 0 J
b) Internal energy:
E = n Cv (Tf - Ti)
Cv = 5/2 * R
E = 1 mol * (5/2) * 8.31 J/mol K * ( 2741.9 K - 300 K)
E= 50730.47 J
c) Work
I've seen the equation in two different ways:
E = Q + W
AND...
E = Q - W
Anyway, I'll use the second one (because is the one I have to use according to the worksheet)...
W = Q - E
W = 0 J - 50730.47 J
W = - 50730.47 J
Is it ok?
Please check it out, because the worksheet doesn't have the answers and I want to know if I did it correctly.
Thanks in advance!
" (25.5 m^3/5.25 m^3)^1.4 * 300 K = Tf "
Do you see an error here? You should be suspicious since you have computed an increase in E while at the same time having done positive work W ( = integral pdV). The 1st law doesn't like that if, as you correctly state, Q = 0 ... in the same vein, computing W as negative can't be right either ...
Tip - I would always use U = Q - W rather than U = Q + W, this defines W as the work done BY the system. This goes back to the early days of thermodynamics when steam engines were the fad and W was of course always positive. (Most people use U rather than E).
I would also add that the formulas for Cv are approximate - you can use the ideal gas law to get a precise answer without reverting to Cv.
Oh thank you. I see it now.
It was 1 - y and I forgot about doing this:
1 - 1.4 = - 0.4
So it plug into the equation the -0.4 instead of the 1.4 It get 113.6 K (final temperature)
So dT would be: 113.6 K - 300 K = - 186.4 K
That means that the Internal Energy is NEGATIVE
Therefore
U = q - w
q = 0
U = - w
w = - U
w = - (- 3873.4 J )
w = 3873.4 J
Is it ok now?
Much better!
Except the internal energy U is not negative; the CHANGE in U is negative.
Thank you again! I can't believe that I skipped that.
So, the final correct answer would be that:
* q = 0
* U = -3873.4 J
* w = 3873.4 J
U negative and w positive
It certainly would be. Except I haven't checked your algebra. But all your equations look right now. And Q = 0, ΔU < 0 and W = - ΔU are all most definitely correct.
  • · Replies 67 ·
11K
