I found a math breakthough .I think
  • Context: High School
  • Thread starter Thread starter Raza
The discussion revolves around a participant's claim of discovering a new method for squaring numbers, accompanied by examples and a general exploration of mental math techniques. The scope includes mathematical reasoning and personal anecdotes related to arithmetic strategies.
  • One participant presents a method for squaring numbers, demonstrating it with examples and claiming a consistent result of 4 when certain operations are performed.
  • Another participant suggests replacing the number with a variable to explore the algebra behind the proposed method.
  • A participant shares nostalgic memories of their own perceived breakthroughs in math during middle school, including tricks for multiplying by 11 and proving relationships between triangles.
  • Some participants express confusion about the original method and seek clarification on the algebraic expressions used.
  • Another participant mentions a different mathematical observation regarding the square of a number and its relationship to surrounding numbers.
  • Several participants discuss mental math techniques and tricks that aid in arithmetic calculations, sharing personal experiences and methods.
  • There are mentions of previously established mathematical principles, with some participants reflecting on the commonality of discovering ideas that have already been explored.
The discussion contains multiple competing views and interpretations of the proposed squaring method, with some participants expressing confusion and others sharing their own mathematical insights. No consensus is reached regarding the validity or utility of the original claim.
Participants reference various mathematical techniques and principles without resolving the underlying assumptions or definitions. The discussion includes personal anecdotes that may not directly relate to the original claim.
Individuals interested in mental math techniques, mathematical reasoning, and personal experiences related to discovering mathematical concepts may find this discussion engaging.
Raza
I found a math breakthough...I think
I just found another way to square a number.
Ex1: 12^2=144
but then this also equal 144
12/2=6 'Number divided by 2
12*2=24 'Number multiplied by 2
24*6=144 <---'Both number multiplied
24/4=4 <---'Both number divided
Ex2: 15^2=225
but then this also equal 225
15/2=7.5 'Number divided by 2
15*2=30 'Number multiplied by 2
30*7.5=225 <---'Both number multiplied
30/7.5=4 <---'Both number divided
Everytime you follow this thing I made up and the divide them, you always get 4.
Please don't insult me if this is stupid because I know I am a idiot. :smile:
Mathematics news on Phys.org
Replace your number with x. Work through the algebra and you will see why things work out the way they do.
Hehe, I remember back in the day when I was in middle school and every other day I'd think I found a break through in math.
I remember being pretty excited at figuring out that for small two digit numbers, when you multiply by 11, all you have to do is simply:
place the first digit first
add the two digits and then place them in the second place digit
place the second digit last
And voila! you get the answer. For example, 43 x 11 =4 (3+4) 3 = 473
I also remember proving that for any two triangles:
if two sides from the first triangle = two sides from the second triangle and the included angles between those two sides add up to 270 degrees, their areas were equal. Not using trig!
Also tried to figure out other ways to find PI but not everything that I tried worked :-p
Hehe, the good old days :-p
Raza, just in case you don't realize what hurkyl said:
[tex]( \frac{x}{2})(2x) = x^2[/tex]
Where do you get formulas written like that?
And I still don't get you always get the answer 4
You need to use latex code to write formulas like that. If you click on any equation written in latex, it shows the code used to type it. There should be a link to the thread in the site FAQ.
[tex]\frac{2x}{\frac{x}{2}}[/tex]
multiply top and bottom by 2:
[tex]\frac{4x}{x} = 4[/tex]
since the x's cancel
I love finding things like this as well. Such as the square of any number is the the two number around it multiplied plus 1. (x-1)(x+1) + 1 = x^2 which is because (x-y)(x+y) = x^2 - y^2
I also found my own equation for pi involving dividing by tan(180/x) or something... but I can't seem to remember it!
Nothing annoyed me more than when I realized that dx/dy(x^y) = yx^(y-1) was already found. :frown:
These 'rules' are really useful when doing arithmetic by head (what's it called in english?), you know, without a calculator.
I used to suck at doing calculations in my head (actually I still do. My short-term memory just leaves at that moment), but applying all these tricks really helped me a lot.
For example: using (x-y)(x+y) = x^2 - y^2.
15*17 (looks tough to me) = (16+1)(16-1)=16^2-1=255.
You'll have to learn the squares from 1^2 to 20^2 by heart. By doing so you can make lots of calculations easier.
13*17=15^2-2^2=221.
This last can be used in conjunction with a trick for squaring a number that ends with 5: Take the number in front of the last 5 and multiply it with that number+1, then glue 25 to the result.
i.e. 15*15=(1)(2) '+' 25=225
65*65=(6)(7) '+' 25 = 4225
Proof: take any number x that ends in 5. Call the number before the 5 d, so that x=10d+5
(10d+5)(10d+5)=100d^2+100d+25=100d(d+1)+25.
Some of my math teachers can multiply two random two-digit numbers effortlessly. I wonder if they are just arithmetic wonders, or use a lot of these tricks...
I never had such a great feel for numbers though.
Okay, I`m going off topic..
13*17=15^2-2^2=221.
I can multiply two digit numbers in my head faster than your average person using a piece of paper.
Do a web search on a fellow called Trachtenberg. BTW this works for all multiplications by 11.
Also, an integer is divisible by 11 if the difference between the sum of its odd-position digits and its even-position digits is divisible by 11. E.g. 192918 is divisible by 11 because 9+9+8-(1+2+1)=22
I don't know why you multiply by 2
Isn't it like this?
[tex]( \frac{x}{2})(2x)[/tex]
[tex]=(\frac{x}{2})(\frac{2x}{1})[/tex]
[tex]=(\frac{x}{2})(\frac{4x}{2})[/tex]
[tex]=\frac{4x^2}{2}[/tex]
[tex]=2x^2[/tex]
[tex](\frac{x}{2})(\frac{4x}{2}) = \frac{4x^2}{4}=x^2[/tex]
When multiplying fractions, you multiply numerators as well as denominators.
If there's one thing I've learned it's that someone has always done something or thought about something well before you. I remember being so happy when I found a relationship between Pascal's Triangle and n-dimensional objects made up of one type of convex polygon. I even did a project on it and placed in the state science fair and nobody told me that it had been done before. I would have gone to ISEF except I had incredibly bad luck and had to compete for a spot in it with an RSI girl... but enough about my past :p. It wasn't until a few months later when I found some website stuck way back in the annals of the web that touched on the subject. Moral of the story: Unless you link two VERY esoteric parts of math, chances are it has been conceived and beaten into the ground.
If you learn to square two digit numbers in your head, you don't have to memorize any.
Any 2 digit decimal number can be converted to Roman Numerals (don't worry, this is a way of thinking about numbers, so you don't actually have to write in Roman Numerals).
36 is XXXVI - you have 3 tens, 1 five, and 1 one.
39 is IXXXX - you have 4 tens and -1 ones.
44 is XXXXIV - you have 4 tens, 1 five, and -1 ones.
The idea is that it's simpler to multiply by tens and fives and then adjust to the precise value. If you modify the Roman Numeral System you learned in school:
33 is XXXIIV - you have 3 tens, 1 five, and -2 ones.
Now you can only have 5 different values for your ones: -2, -1, 0, 1, or 2.
Using that principal, you can break any two digit number into an x + y + z format.
x will be your tens, y will be your fives (it can only be 0 or 5), and z will be your ones (-2, -1, 0, 1, or 2).
Squaring the sum of (x + y + z) is:
[tex]x^2 + 2xy + y^2 + 2xz + 2yz + z^2[/tex]
You can rearrange the second term via commutative property. The fourth and fifth term have 2z in common, so you can use the distributive property to get:
[tex]x^2 + x(2y) + y^2 + (x+y)*2*z + z^2[/tex]
Now, plug in your numbers.
The tens are squared. That's easy. You squaring a one digit number and doubling the number of zeros.
Multiply x by (2 * y). 2*y will either equal 10 (if y is 5) or 0 (if y is 0). Easy step. x is multiplied by 10 or 0. Add this to your first step.
Square y. You get either 25 (y is 5) or 0 (y is 0). Add this to the sum from your second step.
The fourth term is done exactly as it is written: 1) add x + y 2)multiply by 2 3) multiply by z (When you're doing this in your head, it's easier to multiply by 2 twice than it is to multiply by 4 once). Add this to the sum from your third step (z might be negative, so this is the only tough step in the whole procedure).
Square z. Add to the sum from your fourth step.
Example: 36 = 30 + 5 + 1, so:
30^2 is 900
10*30 is 300 giving you 1200, so far.
5^2 is 25, giving 1225, so far.
35 * 2 * 1 is 70, giving you 1295, so far.
1^2 is 1, giving you your final answer of 1296.
33 = 30 + 5 - 2, so:
30^2 is 900
30*10 is 300, giving you 1200.
5^2 gets you to 1225.
35 * 2 * -2 is -140 (or -200 + 60) giving you 1085.
(-2)^2 is 4, giving you 1089.
35 = 30 + 5 + 0
30^2 is 900
30*10 gets you to 1200.
Both the last two steps involve multiplication by 0, so they can be deleted.
That's a cool post BobG. Thanks, I hope it will be of help.
I thought 3 was written III instead of IIV. Nevermind though, it doesn't relate to the calculation anyway.
30^2 is 900
I guess you'll just have to memorize the steps then (and lots of practice ofcourse).
The problem I have is that when there are lots of steps involved I forget what I have done, but since these steps are all easy, the chances of not forgetting increases.
It is. But if you use it as normally written, squaring numbers that end in 3 or 8 are a royal pain. -2 is a lot better number.
  • · Replies 16 ·
  • · Replies 68 ·
13K
