Calculating Friction Force: 12 N, 0.6 & 0.8 Coefficients
The friction force acting on a 0.5 Kg block pushed against a vertical wall with a horizontal force of 12 N can be calculated using the coefficients of friction provided. The static friction force, determined by multiplying the coefficient of static friction (0.6) by the normal force (12 N), equals 7.2 N. Once the block begins to move, the kinetic friction force, calculated using the coefficient of kinetic friction (0.8) and the same normal force, results in a friction force of 9.6 N. Understanding these calculations is crucial for analyzing the forces acting on objects in motion.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction coefficients
  • Ability to calculate normal force in physics
  • Familiarity with free body diagrams (FBD)
  • Study the principles of Newton's laws of motion in detail
  • Learn about the differences between static and kinetic friction
  • Explore how to construct and analyze free body diagrams (FBD)
  • Investigate real-world applications of friction in engineering
Students studying physics, engineers working on mechanical systems, and anyone interested in understanding the dynamics of friction forces in practical applications.
disruptors
A horizontal force of 12 N pushes a 0.5 Kg block against a vertical wall. The block is initially at rest, If static and kinetic coefficients are 0.6 and 0.8 respectively what is the friction force?
Basically the fbd has Force of 12 N across the x component(+) and the Normal force in the opposite (-ve)... The y component is positive facing downwards thus Fnety=mg-frictionforce=ma(y)... Friction force is equal to coefficient of static x Normal... static is 0.6 and Normal force is 12 N, which gives 7.2 N, right?
(i am doubting myself because some other ppl didnt get that)
Thanks
Thats an odd question.
The static Ff would seem to be lower then the kinetic Ff
for asking this question! Your solution looks correct. The friction force can be calculated by multiplying the coefficient of static friction (0.6) by the normal force (12 N). This gives a friction force of 7.2 N, which is the maximum amount of force that can be applied before the block starts to move. Once the block starts moving, the friction force will decrease to the coefficient of kinetic friction (0.8) multiplied by the normal force (12 N), which would give a friction force of 9.6 N. It's important to remember that the coefficient of friction is a measure of the amount of friction between two surfaces, and the actual force of friction will depend on the normal force and whether the object is in motion or at rest. Keep up the good work with your calculations!
  • · Replies 21 ·
