Energy required to heat different materials?
The discussion centers on the calculation of energy required to change the temperature of materials, specifically using the formula Q=mcΔT. A 10 kg block of marble with a specific heat capacity of 600 J/(kg°C) requires 6,000 joules to increase its temperature by 1°C. The energy calculated is indeed in joules, confirming that Q represents energy. Additionally, the same formula applies for decreasing temperature, with the sign of ΔT reflecting the direction of the temperature change.
  • Understanding of specific heat capacity
  • Familiarity with the formula Q=mcΔT
  • Knowledge of units of energy (joules)
  • Basic principles of thermal physics
  • Research the concept of specific heat capacity in different materials
  • Learn about the implications of temperature changes in thermal physics
  • Explore the relationship between mass, temperature change, and energy in thermal systems
  • Investigate practical applications of specific heat capacity in engineering
Students studying thermal physics, educators teaching heat transfer concepts, and professionals in engineering fields focusing on material properties and energy calculations.
J-Girl
Hello:) I am doing thermal physics at the moment, and am up to the part on specific heat capacity. I know that the equation Q=mc[itex]\Delta[/itex]T refers to the amount of energy required to raise the temperature by 1 degree celsius, but I am just a bit confused about how the energy is calculated. For example, if i have a 10kg block of marble with specific heat capacity of 600, and i want to know how much energy is required to increase the temperature by 1 degree celsius, and i do: Q=(10)(600)(1), and my final answer is 6,000, is it in joules, because its energy? Also, if i want to know how much energy is required to DECREASE the temperature by 1 degree celsius, do i do Q=(10)(600)(-1)?
thanks:):)
Hi J-Girl,
The specific heat capacity 'c' is defined as the energy needed to heat 1 g (or maybe 1 kg) of material by 1°C. As a result, it has dimensions of energy per unit mass and per unit temperature. This corresponds to units of J/(g°C) or J/(kg°C). You need to find out which of these two options are the units your stated c value of "600" is in.
But, you can see that with these units, everything will work out as needed -- from the equation, Q will turn out to be in joules.
