Gravitational Effects: How Jupiter Impacts Mars' Orbit
  • Context: Undergrad
  • Thread starter Thread starter Frannas
    Effects Gravitational
The discussion centers on the gravitational effects that Jupiter has on Mars' orbit, exploring how the presence of a larger planet influences the orbital path of a smaller nearby planet. The scope includes theoretical considerations of gravitational forces, orbital mechanics, and the implications of these interactions over time.
  • One participant questions the effects of Jupiter on Mars, seeking clarification on how Jupiter influences Mars' orbital path.
  • Another participant presents the gravitational force equation, indicating the relationship between the masses of Mars and Jupiter and their distance.
  • It is noted that Jupiter causes the precession of Mars' orbit.
  • A different viewpoint suggests that while Jupiter contributes to the precession of Mars's rotational axis, it does not change the orbital path directly.
  • Participants discuss how the relative positions of Jupiter and Mars affect the net gravitational acceleration experienced by Mars, leading to variations in its orbit.
  • There is a detailed explanation of how the conjunction and opposition of Jupiter and Mars could lead to changes in the shape of Mars' orbit over time, with implications for its semi-major axis.
  • One participant emphasizes that the gravitational effect of Jupiter on Mars is small and would require long-term analysis to detect significant changes.
Participants express differing views on the extent and nature of Jupiter's influence on Mars' orbit. Some agree that Jupiter affects Mars' orbital characteristics, while others contest the direct impact on the orbital path itself. The discussion remains unresolved regarding the precise implications of these gravitational interactions.
Participants acknowledge that the effects discussed are subtle and depend on various assumptions, including the positions of the planets and the nature of their orbits. The complexity of gravitational interactions and the long timescales involved in observing changes are also noted.
Frannas
I know this question may be a bit vague, and probably needs better wording, but I struggle to rephrase it.
What is the effect that a larger planet eg. Jupiter has on a smaller nearby planet eg. Mars?
This question is based mainly on the orbital path of both planets, how is it influenced?
Astronomy news on Phys.org
Jupiter causes Mars' orbit to precess.
Jupiter does contribute to the precession of Mars's rotational axis, but that won't change the orbital path.
If Jupiter is on the same side of the Sun as Mars, then the acceleration of gravity due to Jupiter should be subtracted from the gravitational acceleration due to the Sun. If Mars were in a circular orbit (which it's not), then the reduced net acceleration would mean Mars was going too fast for a circular orbit, which would create an elliptical orbit with apogee on the opposite side of the Sun than Mars & Jupiter.
If Jupiter is on the opposite side of the Sun as Mars, then the opposite occurs. Acceleration due to Jupiter has to be added to the acceleration due to the Sun, which increases the net acceleration, meaning Mars is going too slow to maintain a circular orbit. Perigee will be on the opposite side of the Sun from Mars.
Which is why Mars isn't and can't be in a perfectly circular orbit.
If the Jupiter/Mars conjunction/opposition always occurred in exactly the same spot, then the orbit would slowly become more elliptical. Since Jupiter is so much further away when in opposition, perigee would decrease at a slower rate than apogee increased, meaning the semi-major axis would slowly increase. If the conjunction/opposition rotated around Mars's orbit, then you'd have a slow cyclic increase/decrease in your parameters. Jupiter's orbit is 6.307 times longer than Mars's orbit, meaning the latter would be the case.
Slowly is an understatement. Using the mass of Jupiter, the mass of the Sun, and the semimajor axes of Mars and Jupiter, and Newton's Universal Law of Gravitation, you should be able to calculate how much Jupiter adds or subtracts from the acceleartion due to the Sun. The effect of Jupiter is so small it will barely be detectable except by a long term analysis of Mars's orbit.
  • · Replies 24 ·
  • · Replies 86 ·
9K
