| New Reply |
CERN team claims measurement of neutrino speed >c |
Share Thread | Thread Tools |
| Jun12-12, 11:17 AM | #783 |
CERN team claims measurement of neutrino speed >cSecond, they found another error due to an oscillator, contributing 15ns in the opposite direction. Together, those effects caused the 59ns "anomaly". That's all. Also note that in October-November 2011 (before the cable was fixed), OPERA used short bunched beams, which evaluation didn't require those statistics - also here the discrepancy was 60 ns. But ICARUS measured the same bunched beam at the same time, and found no discrepancy. And in May 2012, another bunched beam run was performed, and OPERA, ICARUS, LVD, Borexino found no discrepancy too. Opera: What went wrong End of the Opera story |
| Jun12-12, 11:59 AM | #784 |
| Jun12-12, 12:52 PM | #785 |
neutrinos actually had that broad variation in their speed but just shifted 59ns to have close to light speed average? |
| Jun12-12, 01:04 PM | #786 |
| Jun12-12, 01:10 PM | #787 |
| Jun12-12, 01:12 PM | #788 |
| Jun12-12, 01:24 PM | #789 |
Note that the mentors have repeatedly told posters to read the original opera paper before posting here, anyone that has read it or has some notion about the relation of distance versus time (in ns or any other units) should see how the different δt (in ns) are related to neutrino speeds.
| Jun12-12, 01:39 PM | #790 |
Mentor
Why is the original OPERA paper still being debated here? It is clear that the result from that paper no longer holds water.
Zz. |
| Jun12-12, 01:50 PM | #791 |
So far I've obtained two different explanations to my query, one that the loose wire error is purely sistematic and fixed (74ns) and the other that it actually it is responsible for the broad variation of [itex]\delta[/itex]t in the first longer Opera experiment from 2008-2011.
Both answers are incompatible; as I said since the cable problem is considered a sistematic error I was thinking in terms of the first explanation, and with the reasonable assumption that neutrinos speed cannot oscillate so much in such a short distance (732km), I'm still missing something in the sense that the offered solution would work perfectly if the 60ns [itex]\delta[/itex]t was not just an average. Of course my concern is only directed to the original experiment, not to the recent brief short pulsed ones. But I think it is important given the uproar it generated to have it all well clarified. |
| Jun12-12, 01:53 PM | #792 |
| Jun12-12, 01:56 PM | #793 |
Mentor
It makes discussion of the original paper to be entirely moot! Zz. |
| Jun12-12, 01:57 PM | #794 |
Note also that my questions were about that paper in the light of the new information released about the possible source of errors.
| Jun12-12, 02:03 PM | #795 |
| Jun12-12, 02:09 PM | #796 |
Mentor
The same "philosophy" what was imposed upon in the beginning to urge people to read the original OPERA paper BEFORE they jump in into this discussion is also at work here. It means that the discussion must be based on something concrete, rather than something pluck out of thin air without any basis. Until the OPERA group publish clearly the post-mortem of the original result, you and I do not possess any kind of data or information to make an informed discussion of what actually happened. So how would such a discussion gives you a "better understanding"? A better understanding on how to make guesses? Zz. |
| Jun12-12, 02:30 PM | #797 |
| Jun26-12, 04:15 AM | #798 |
I read your question like “How could there be such a wide distribution in arrival times of neutrinos? Is it due to the loosing cable?” If this was your question, then the answer is that the loosing cable caused (mainly) a systematic error which shifted the time distribution without deforming it significantly. This mean that the variance of the time distribution is still there when you fix the cable. It is due mainly to three contributions (to my knowledge): a difference in neutrinos velocity, that is though negligible; a difference in the path followed (they are not created and received all in the same starting and ending points); other experimental errors. I hope this could help. Sorry for the bad English, Ilm |
| Jun26-12, 12:02 PM | #799 |
Mentor
The wide time distribution in the original publication has a simple explanation: The proton beams used to produce the neutrinos were long (~10µs if I remember correctly). Timing was not the main purpose of the experiment, just something which could be done in addition to the mixing measurements. After timing became interesting, they used short pulses (2ns?), as they are better to measure the flight time.
The 60ns were obtained by comparing the proton distribution (in time) with the neutrino distribution. Compared to the speed of light, a shift (but no broadening of relevant size) between the two was observed. |
| New Reply |
| Tags |
| anisotropy, cern, ftl, gps, new math books |
| Thread Tools | |
Similar Threads for: CERN team claims measurement of neutrino speed >c
| CERN, speed of light... | Special & General Relativity | 6 | ||
| does neutrino oscillation from electron neutrino to muon neutrino conserve energy? | High Energy, Nuclear, Particle Physics | 4 | ||
| Avg Speed of Relay team (x and t are not given) | Introductory Physics Homework | 1 | ||
