Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Closed Thread
image Clock Synchronization Share It Thread Tools Search this Thread image
Old Nov19-04, 03:51 PM       Last edited by juju; Nov19-04 at 03:54 PM..            #1
juju
juju is Offline:
Hi,
I have been thinking that in order to actually prove Einstein's second postulate of SR about the speed of light (and SR in general) you need to make a one-way measurement of the velocity of individual photons. To do this the clocks at the two ends of the path have to be synchronized. My question is how do you synchronize these clocks without assuming the second postulate (or other parts of SR) is true in the first place.
juju
Old Nov20-04, 09:57 AM                  #2
selfAdjoint
selfAdjoint is Offline:
Recognitions:
PF Contributor PF Contributor
Retired Staff Retired Staff
Think of each clock as a a twin, in the famous twin "paradox". The clocks keep proper time in their own rest frames. And the point of the twin story is that even if they are synchronized at one moment in the same frame, their subsequent travels over curved world lines (i.e.accelerations) will cause them to read differently when they are brought back together. And when they are apart, you can't have them synchronized at all, either they are matched at different times and relative speeds (by radio or light signals) and so they tell different times by Lorentz transformations, or else they are spacelike related in which case the concept of simultenaity, necessary for synchronization, simply does not exist.
Old Nov20-04, 03:37 PM                  #3
juju
juju is Offline:
Hi SelfAdjoint,
The conclusion I am tempted to deduce is that many aspects of special relativity cannot actually be tested adequately because they require the assumption of certain other aspects of relativity for their test.
juju
Old Nov20-04, 05:30 PM                  #4
selfAdjoint
Recognitions:
Originally Posted by juju
Hi SelfAdjoint,
juju
Only if you define naive experiments
There have been thousands of experiments supporting the Lorentz transformations, and from the Lorentz transformations you can deduce the rest of relativity.
Old Nov21-04, 05:13 PM                  #5
juju
juju is Offline:
Hi,
OK, then. How do I synchronize two clocks, 10 miles apart, in order to measure the one way speed of light on the surface of the earth. Do this without assuming any part of relativity.
juju
Old Nov22-04, 02:57 AM                  #6
4newton
4newton is Offline:
At noon time you take two clocks 10 miles apart. At some point in between the two clocks near the middle you send a signal to both clocks and reset them. The clocks then send signals to you and arrive at your location together after the reset. As the earth turns the pulse of one clock should arrive before the other and reach a maximum difference around midnight. As the earth returns to noon at your location the clocks should again agree. If you see a difference then the one way speed of light is different.
Old Nov22-04, 06:01 PM                  #7
juju
juju is Offline:
Hi 4Newton,
Doesn't sending the original signal to reset the clocks assume that the speed of light in both directions is the same, and is not the same true of the first signal that you get from the clocks.
juju
Old Nov23-04, 03:03 AM                  #8
4newton
4newton is Offline:
Hi juju:
The reason to send the first sync pulse is to remove all differences in the system at the start. This gives you a starting point of zero difference for the velocity you are moving on the earth at the start. As your relative velocity changes as the earth rotates the pulses should change if the one way path of light changes.
To have higher resolution you can start a counter time base when one pulse is received and stop counting when the other pulse is received. You may accumulate this count over any time period to achieve the resolution desired.
image image
Closed Thread
Thread Tools
Similar Threads for: Clock Synchronization
Thread Thread Starter Forum Replies Last Post
non-standard clock synchronization bernhard.rothenstein Special & General Relativity 10 Feb27-08 01:05 PM
clock synchronization bernhard.rothenstein Special & General Relativity 10 Dec23-07 03:00 PM
clock synchronization problem bernhard.rothenstein Special & General Relativity 7 Apr24-07 12:43 PM
is clock synchronization compulsory bernhard.rothenstein Special & General Relativity 51 Feb12-07 12:32 PM
clock synchronization bernhard.rothenstein Special & General Relativity 2 Jul25-06 03:43 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
