Calculating Work Done by a Gas Using the PV=1000 Equation | Thermo Help
  • Thread starter Thread starter bradycat
    Concept Stuck
The discussion centers on calculating the work done by a gas using the equation PV=1000, where P represents pressure in kPa and V denotes specific volume in m³/kg. The correct method to determine work involves using the formula for net flow work, specifically W = P2V2 - P1V1. The calculated work done by the gas when the pressure decreases from 1000 kPa to 500 kPa is 693.1 kJ/kg. Participants clarify that the force is not constant, emphasizing the importance of understanding variable pressure in thermodynamic calculations.
  • Understanding of thermodynamic principles, specifically work done by gases
  • Familiarity with the ideal gas law and its applications
  • Knowledge of pressure-volume relationships in thermodynamics
  • Basic calculus for integrating variable forces
  • Study the derivation of the work done by gases in variable pressure scenarios
  • Learn about the ideal gas law and its implications in thermodynamic processes
  • Explore the concept of specific volume and its significance in thermodynamics
  • Investigate the application of calculus in calculating work done in non-constant force situations
This discussion is beneficial for students and professionals in thermodynamics, mechanical engineers, and anyone involved in calculating work done by gases in various pressure conditions.
bradycat
A gas expands according to the equation pv=1000. where p is pressure in kPa and v is specific volume m^3/kg. If the gas pressure drops from 1000 to 500kPa, how much work was done by the gas??
Ok I am new to thermo and given a question and can't figure it out.
Do I use net flow work = p2v2-p1v1??
Answer is 693.1 kJ/kg.
or is it w-p delta v?
I am not sure.
Any help or direction would help thanks
Start from
work = force x displacement
BUT remember that the force is not constant.
