Compiling C: What Do Experts Use?
  • Thread starter Thread starter Bob Busby
The discussion revolves around the tools and methods used by participants for organizing and compiling C projects. It includes perspectives on Integrated Development Environments (IDEs), command-line tools, and makefiles, with a focus on personal preferences and experiences in different environments.
  • Historical
  • Some participants express that IDEs are often bloated and slow, while makefiles can be confusing to write.
  • One participant mentions using vi, make, and gcc, but notes their experience as an "old-timer" and does not recommend this approach to others.
  • Another participant describes a complex setup using Visual Studio, where batch files are utilized to manage builds, including version control and environment setup.
  • There is a discussion about how IDEs manage the compilation process by calling separate processes for compiling and linking, which some participants find acceptable on decent computers.
  • One participant shares their experience with vi/vim, highlighting its command-line interface as preferable to the popups in IDEs, while also acknowledging the challenges of using makefiles in conjunction with IDEs.
  • A participant recalls their early programming experiences with QB and assembler, contrasting it with modern IDEs like Visual Studio, indicating a significant evolution in tools over time.
  • Another participant mentions using pico in a *nix environment, sharing a less favorable experience with emacs during remote compilation.
Participants express a variety of preferences for tools and methods, indicating no consensus on the best approach. Some favor traditional command-line tools, while others prefer the features of modern IDEs, leading to a mix of opinions and experiences.
Participants' experiences are influenced by their backgrounds and the complexity of their projects, with some noting that their approaches may not be suitable for all users or scenarios.
Bob Busby
IDEs are bloated and slow usually and makefiles are confusing to write by myself. I was just wondering what you experts do to organize and compile projects with.
Technology news on Phys.org
I use vi, make and gcc. But I am an old-timer, wouldn't recommend it to anyone else.
Depends on how complex the project is. Note that Visual Studio includes a dos console window under programs / ... visual studio ... / tools, where you can use cl and link (and ml if you want to do assembly programs). If it's just a single module, I just use cl. If it's a few modules, I create a batch file.
For the most complex setup I've used at work, the user can create an empty directory and get a single batch file that will get everything needed from version control and do a build. In some cases that same batch file can be used with an existing directory, only updating anything that is out of date (mostly makefile). The batch file gets the build tools, (nmake, ml, cl, link, ...), via version control, sets environment variables, creates the entire directory tree, then switches to a large makefile that gets source files if not present or out of date, then does the actual build process. The build tools are included so that old code is built with the same versions of the tools used to originally build the old code.
One trick in the batch file for real dos or dos console windoes to allow it to be used with either empty or existing directories is the ability to test for the existence of a directory by looking for a file named "nul" in that directory:
Code:
if not exist exampledirectory\nul    md exampledirectory
I don't recall being able to duplicate this with an makefile, but once the directories are created, then the makefile has no problem checking for existence of files or out of date files.
In addition to visual studio, old copies of visual c 4.0 (32 bit) and 2.2 (16 bit), are used to work with old projects.
You should understand that many IDE's call separate processes that compile different source files and link these modules to create an EXE, DLL, or other binary object.
Usually what can happen is that the IDE calls these processes and simply pipes the output to an output window of some sort.
If you have a decent computer (not top of the line, but average), this should not be a major issue.
Also an old-timer, so take my comments with a grain of salt.
vi/vim can be fairly magical, particularly when you have magic enabled. On the other hand, vim (who uses vi nowadays?) is a rather dimwitted editor, even with ctags (which don't work quite so well with an OO language where names intentionally overlap). I like the command line concept in vim versus the popups that tend to pervade IDEs; I find that those popups to be slow, distracting, and disconcerting. Some people justifiably do like the added power of an IDE, and find the modal behaviors of vi, vim and emacs to be distracting and disconcerting.
Regarding makefiles, I sometimes have to use external tools that write makefiles. (Using an IDE in these situations can be a bit tough, when the external tool and the IDE contend over who owns the makefile.) When I am in control, if the makefile is simple I just write the makefile. If the makefile will be of any complexity, I will either
  • include some master makefile I have written earlier and add the few lines need to make that master makefile work. I find this approach to be very useful for unit tests. My unit test makefiles tend to be very small thanks to the include capability.
  • Build a Configure script that generates a top level makefile in some project. This top level makefile will inevitably contain a makefiles target that invokes some secondary script to build makefiles in applicable subdirectories, each of which has a makefiles target as well.
    The underlying machinery can be a bit convoluted, but usage is simple: Just type make.
I remember back when I started learning to program using QB and Assembler/Machine code you had to do all the compiling and linking of stuff by hand (The assembler stuff) and when I first used Windows Visual Studio 6, it was like the transition of going from a TV without a remote to with one.
The only thing I've used in a *nix environment was pico. I'm not a linux user anyway, but at least with pico you could telnet into the environment from a windows machine and the graphics environment with pico was all hunky-dory! I remember when I used emacs on the telnet session, everything went to crap. This was for remote compilation for uni-work quite a while back though.
  • · Replies 0 ·
  • · Replies 20 ·
10K
  • · Replies 17 ·
