Something is broken about black hole theory
The discussion revolves around the complexities and paradoxes associated with black hole theory, particularly focusing on the behavior of objects as they approach the event horizon. Participants explore concepts related to velocity, mass, gravitational effects, and the implications of general relativity in these scenarios.
  • Some participants propose that as an object falls into a black hole, its velocity approaches the speed of light at the event horizon, while others challenge this assertion, questioning the validity of the claim.
  • There is a contention regarding the idea that the mass of an object becomes infinite as it approaches the event horizon, with some arguing that this is a misunderstanding of the physics involved.
  • A later reply discusses the relationship between kinetic energy and gravitational potential energy, suggesting that while energy increases as particles fall inward, the effective mass of the black hole does not increase correspondingly.
  • Participants discuss the implications of tidal forces on objects approaching black holes, noting that larger black holes may not rip apart objects until they are inside the horizon, while smaller black holes may do so before reaching the event horizon.
  • There are inquiries about the nature of energy and gravitational effects in relation to black holes, with some questioning whether energy can be "stolen" from a black hole.
  • One participant references historical literature on relativity, indicating that misconceptions about mass increase at relativistic speeds have persisted in discussions about black holes.
Participants express multiple competing views on the behavior of objects near black holes, particularly regarding velocity, mass, and gravitational effects. The discussion remains unresolved with no consensus reached on several key points.
Some claims rely on specific interpretations of general relativity and may depend on definitions of mass and energy. There are unresolved mathematical steps and assumptions regarding the behavior of objects at and near the event horizon.
x_engineer
A simple paradox -
Imagine something falling into a black hole, starting at infinity. When it gets to the event horizon, its velocity has to be c. However, from the perspective of an observer outside the event horizon, its mass has become infinite, which means it would also have an event horizon and that event horizon swallows the entire universe. Thus if anything actually falls into a black hole, the entire universe also winds up inside the black hole.
OK, maybe we never get so see something actually fall in.
Astronomy news on Phys.org
Why would that be the case? That's not true.
That's not true either.
The whole premise of this thread is wrong. Just because you don't understand something that you have not studied does not mean something is broken in the theory.
Well according to Edwin F. Taylor and John Archibald Wheeler in their book Exploring Black Holes - Introduction to General Relativity, chapter 3, it is true. From Figure 5. p 3-16 [a graph showing the infalling velocities of an object from different frames of reference] "At the horizon, the shell speed rises to the speed of light (equation [24]) while the bookkeeper speed drops to zero (equation [21])."
It is not true however that mass increases as the object approaches c because although the object is accelerating, it is not being accelerated. Even if it were being accelerated, it is the momentum, not the mass that increases.
skeptic2 said:
Well according to Edwin F. Taylor and John Archibald Wheeler in their book Exploring Black Holes - Introduction to General Relativity, chapter 3, it is true for proper time.
What is true? That the radial velocity of the particle approaches c? The general equation, in schwarzchild space - time, for radial acceleration is [tex]\frac{1}{2}(e^{2} - 1) = \frac{1}{2}(\frac{dr}{d\tau })^{2} - \frac{M}{r} + \frac{L^{2}}{2r^{2}} - \frac{ML^{2}}{r^{3}}[/tex] For a particle starting off at r = infinity falling in radially this reduces to [tex]\frac{dr}{d\tau } = (\frac{2M}{r})^{1/2}[/tex] so at r = 2M we have [itex]\frac{dr}{d\tau } = 1[/itex] so yes it does approach c. As you know, the velocity [itex]\mathbf{U}[/itex] of a particle can be written in terms of components in the default coordinate chart on the scwarzchild 4 - manifold (valid outside r = 2M) and of this we have [itex]U^{r} = \frac{dr}{d\tau }[/itex] but keep in mind that this is coordinate velocity. If you transform to eddington coordinates then you can make the singularities at r = 2M disappear so while [itex]\frac{dr}{d\tau }\rightarrow 1[/itex] as [itex]r\rightarrow 2M[/itex] this is a coordinate based result. As stated, a coordinate transformation to something non - singular at r = 2M will get rid of that result. Coordinate singularities tell us nothing about the actual geometry of the 4 - manifold in question.
BZZZT.
In 1940, a physicist named George Gamow published a popular book on relativity called Mr. Tompkins In Wonderland. In that book, he made the statement that when objects travel fast, they behave as if their mass increases.
In the subsequent decades, many a physicist wishes that Gamow hadn't said that because, it leads to all sorts of confusion. When something gets close to c, it gets harder to make it go faster, but it's gravitational force does *NOT* increase, and if you kick it from the side, it won't behave differently.
This is true.
Thanks twofish_quant.
I could see my understanding of what happens to an object moving close to the speed of light is not correct. So, just to be clear, all that energy does not create a gravitational field?
The answer to your question is, I believe, more subtle than the answers that have been given here, and it is a puzzling aspect of general relativity that was really not clarified until R.C. Tolman explained it in 1930. Imagine a cloud of 'dust' (non-interacting particles) collapsing from infinity under their mutual gravitational attraction. As they accelerate inward, they gain kinetic energy. The right-hand side of Einstein's field equation does not contain just the mass of the particles, but contains the full stress-energy tensor. So the [tex]T_{00} = \sum (m^2+p^2)[/tex] term on the right-hand side is the total energy of all of the particles, which clearly increases as the particles accelerate inward. And yet we know that the effective mass of the black hole does not keep increasing as they fall inward, and even simple Newtonian theory tells us that the gravitational field depends only on the total mass inside. So what is going on? The answer is that the energy to accelerate the particles is coming from the gravitational potential energy, which is decreasing as the particles fall inward by the same amount as their kinetic energy is increasing. This needs to be taken into account, and when it is, the total energy on the right-hand side of Einstein's equation is just the mass (or rest mass) of the particles, and it does NOT increase as they fall inward.
Here's a reference,
"Tolman, R.C., "On the Use of the Energy-Momentum Principle in General Relativity", Phys Rev, V35 #8, P.875, Apr. 15, 1930.
phyzguy: Thanks!
Would the corollary be that energy is stolen from the black hole? I seem to have read some things about the black hole disappearing just before passing the event horizon from the point of view of the infalling object. From a remote observer's point of view the crossing never happens (or rather it happens in the indefinite future).
Also, there is all this talk about tidal forces ripping you apart before you reach the event horizon. Would this necessarly be true for a large enough black hole? I can visualize the math going either way.
The larger the black hole, the smaller the tidal force at the event horizon. For a very large black hole, you are not ripped apart until you are inside the horizon. For a very small black hole, you are ripped apart above the horizon.
I don't think so. There are ways of removing rotational energy from a rotating black hole, but no way of removing gravitational energy from a static one.
Probably not the best way of describing what happens. The event horizon is the limit at which once you cross it, you can no longer cross back. However, when you do cross the event horizon, you don't notice anything odd at all.
From a remote observers point of view, you never see someone crossing the event horizon, because the light gets infinitely redshifted. But it does.
What you will see when someone crosses the event horizon is that they will disappear.
It happens with small black holes but not large ones.
Here are some equations you might find useful regarding an object falling from rest at infinity towards a static black hole (this is often referred to as the rain frame), [itex]M=Gm/c^2[/itex] (equations taken from 'Exploring Black Holes' by Taylor & Wheeler)-
E/m (energy/mass ratio of the object)-
[tex]\frac{E}{m}=\left(1-\frac{2M}{r}\right)\frac{dt}{d\tau}\ =\ 1[/tex]
where [itex]d\tau[/itex] is the time dilation for an object in free fall from infinity which in this case is the sum of both the time dilation for gravity and velocity- [itex]d\tau=\sqrt(1-2M/r)\cdot\sqrt(1-v^2)=(1-2M/r)[/itex] where [itex]v=\sqrt(2M/r)[/itex] for an object which has fallen from rest at infinity (see below).
Eshell/m (energy/mass ratio of object relative to shell frame)-
[tex]\frac{E_{shell}}{m}=\left(1-\frac{2M}{r}\right)^{-1/2}[/tex]
Note- This is energy as observed at a specific radius as the object falls radially towards the BH and while the above tends to infinity at the EH, there would be no static observer at the EH.
vshell (velocity of object relative to shell frame)-
[tex]v_{shell}=\left(\frac{2M}{r}\right)^{1/2}[/tex]
Note- No stable shell frames with the EH.
v (velocity of in-falling object as observed from infinity, dr/dt)-
[tex]v=\left(\frac{2M}{r}\right) \left(\frac{2M}{r}\right)^{1/2}[/tex]
Regarding tidal forces-
[tex]dg=\frac{2Gm}{r^3}dr[/tex]
which can be rewritten in respect of a change of 1g from head to toe (i.e. dr=2m)-
[tex]r_{ouch}=\left(\frac{2Gm}{g_E}dr\right)^{1/3}[/tex]
and as previously stated, this 'ouch' radius will occur outside the EH of small black holes and inside the EH for very large black holes.
Regarding your following statement-
See question 4 in the following link-
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/fall_in.html"
Why does the term on the right hand side survive the r->infinity limit? Sure, it goes to zero slower than the others, but if we assume the ideal point r=infinity, it is also zero. You can basically think about it like this: Schwarzschild geometry is asymptotically flat (i.e. minkowski at infinity). Thus if we drop a particle "at infinity" (which is of course an idealization), it will not move at all since it doesn't feel the gravitational field.
That's not why it survives and the others don't. I said a particle falling in radially from infinity. The other terms vanish because L = 0 for a particle falling radially and e = 1 at r = infinity.
True, didn't notice that at first, sorry. However, my argument still holds.
  • · Replies 16 ·
