| New Reply |
errors with s-function level 1 in simulink |
Share Thread | Thread Tools |
| Sep25-11, 09:34 PM | #1 |
Hi all,
I am modeling a separator model with pressure and water level as 2 variables. I first made an m-file(hamda.m) with ode23tb, which is working( 4 plots: pressure, water level, flow of liq output and flow of gas output. then I used an level 1 s-function( gabileh) applying the m-file(hamda.m) I created as fellow function [sys,x0,str,ts,simStateCompliance] = gabileh(t,x,u,flag,varargin) % M-File S-Function implementing QLi = u(1); Qgi = u(2); kv1 = u(3); kv2 = u(4); switch flag, %%%%%%%%%%%%%%%%%% % Initialization % %%%%%%%%%%%%%%%%%% case 0, [sys,x0,str,ts, simStateCompliance] = mdlInitializeSizes(t,x,u,flag); %%%%%%%%%%%%%%% % Derivatives % %%%%%%%%%%%%%%% case 1, sys = mdlDerivatives(t,x,u,QLi,Qgi,kv1,kv2); %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Update, Output, and Terminate % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% case {2, 4, 9}, sys = []; % do nothing %%%%%%%%%% % Output % %%%%%%%%%% case 3 sys = mdlOutputs(t,x,u); otherwise DAStudio.error('Simulink:blocks:unhandledFlag', num2str(flag)); end % %====================================================================== ============= % mdlInitializeSizes % Return the sizes, initial conditions, and sample times for the S-function. %====================================================================== ============= % function [sys, x0,str,ts] = mdlInitializeSizes sizes = simsizes; sizes.NumContStates = 2; sizes.NumDiscStates = 0; sizes.NumOutputs = 4; sizes.NumInputs = 4; sizes.DirFeedthrough = 0; sizes.NumSampleTimes = 1; sys = simsizes(sizes); x0 = []; str = []; ts = [0 0]; % continuous sample time: [period, offset] % Specify the block simStateCompliance. The allowed values are: % 'UnknownSimState', < The default setting; warn and assume DefaultSimState simStateCompliance = 'UnknownSimState'; % end mdlInitializeSizes % %====================================================================== ============= % mdlDerivatives % %====================================================================== ============= % function sys = mdlDerivatives(t,x,u,varargin) QLi = u(1); Qgi = u(2); kv1 = u(3); kv2 = u(4); sys = hamda(t,x,u); % end mdlInitializeSizes %====================================================================== ======= % mdlOutputs % Return the output vector for the S-function %====================================================================== ======= % function sys = mdlOutputs(t,x,u) sys =Qgt; sys =QLt; sys = x; % end mdlOutputs when I used the level-1 s-function in a simulink with 4 inputs and 4 ouputs, I keep having the same error: Error in 'seprig/M-file S-Function1' while executing M-File S-function 'gabileh', flag = 0 (initialize), at start of simulation. MATLAB error message: Attempted to access u(1); index out of bounds because numel(u)=0. please help, thanks in adavance |
| New Reply |
| Thread Tools | |
Similar Threads for: errors with s-function level 1 in simulink
| S-function! in Simulink/Matlab | Differential Equations | 0 | ||
| Need help on Simulink | Programming & Comp Sci | 1 | ||
| Simulink help | Mechanical Engineering | 6 | ||
| SIMULINK - need help | Electrical Engineering | 0 | ||
