| New Reply |
Can somebody help translate this question? 2D Kinematics. |
Share Thread |
| Sep27-11, 10:23 PM | #1 |
I'm having difficult understanding the question, can somebody help me? The question is:
"The velocity of a 3 kg particle is given by v = (3ti + 6(t^2)j )m/s, with time t in seconds. At the instant the net force on the particle has a magnitude of 35 N, what are the direction (relative to the positive direction of the x axis) of (a) the net force and (b) the particle's direction of travel? Answer: (a) 75.099403312170 Units ° (degrees) (b) 61.978933315223 Units ° (degrees)" My initial approach was to find t when the magnitude of the particle is 35N to get the components of the triangle. Velocity and Acceleration v = 3ti + 6(t^2)j a = 3 + 12t Time F = ma 35 = 3(3+12t) 35 = 9 + 36t 26 = 36t .72 = t Since, I thought I was to find the angle created by the velocity vector, I found the y-comp. (opp.) and x-comp. (adj.). y-comp. = 6(t^2) = 6(.72^2) = 3.13 x-comp. = 3t = 3(.72) = 2.27 tan(theta) = opp./adj. = 3.13/2.27 theta = arctan(3.13/2.27) = arctan(1.44) = 55.27 However, 55.27 isn't the angle... for anything! Did I misinterpret the question? What is the difference between the two angles they are asking me to find, what are they asking of my specifically? If somebody can help me I would deeply appreciate it. Thank you for taking the time to read my question. |
| Sep27-11, 10:38 PM | #2 |
Recognitions:
Should the acceleration also have had an i and j component. |
| Sep27-11, 10:59 PM | #3 |
Velocity and Acceleration v = 3ti + 6(t^2)j a = 3i + 12tj Time F = ma 35 = 3(3i+12tj) 35 = 9i + 36tj ..? help? |
| Sep27-11, 11:06 PM | #4 |
Recognitions:
Can somebody help translate this question? 2D Kinematics.(35/3)2 = 32 + (12t)2 That will let you find t, so then substitute into velocity and acceleration expressions to find the directions and magnitudes. |
| Sep27-11, 11:14 PM | #5 |
Recognitions:
| Sep27-11, 11:34 PM | #6 |
| Sep28-11, 07:24 PM | #7 |
| Sep28-11, 07:36 PM | #8 |
Mentor
The direction of the velocity is the direction of travel.
| Sep28-11, 10:01 PM | #9 |
| New Reply |
| Tags |
| angle, force, kinematics, newtons, trigonometry |
Similar discussions for: Can somebody help translate this question? 2D Kinematics.
| Does the earth translate around the sun? | Classical Physics | 7 | ||
| Chain rule: please translate | Calculus | 2 | ||
| Will someone please translate this to English? | General Discussion | 10 | ||
| Translate something for me? | General Discussion | 4 | ||
| Can you translate this for me ?? | General Discussion | 86 | ||
