Fluids (Find the Force Exerted)
  • Thread starter Thread starter Bcisewski
    Fluids Force
The discussion centers on calculating the force exerted by mercury on a circular plug at the bottom of a tank. The correct force is determined to be 25.4 N, calculated using the formula F = pA, where p is the pressure derived from the density of mercury (13,600 kg/m³), gravitational acceleration (9.81 N/kg), and the height of mercury (0.376 m). The initial attempts to calculate the force were incorrect due to misapplication of the density in pressure calculations. The final correct approach assumes atmospheric pressure above the mercury is negligible.
  • Understanding of fluid mechanics principles, specifically pressure and force calculations.
  • Familiarity with the formula for pressure: p = F/A.
  • Knowledge of density and its relation to mass and volume: ρ = m/V.
  • Basic understanding of gravitational effects on fluids.
  • Study the derivation of hydrostatic pressure in fluids.
  • Learn about the applications of Pascal's principle in fluid mechanics.
  • Explore the implications of atmospheric pressure in fluid calculations.
  • Investigate the effects of fluid density variations on force calculations.
This discussion is beneficial for students and professionals in physics, engineering, and any field involving fluid dynamics, particularly those focusing on pressure calculations and hydrostatics.
Bcisewski
Need some assistance on what I am missing
"A tank contains mercury, whose density is 13 600 kg/m3. Find the force exerted by the mercury on a circular plug at the bottom of the tank. The plug has a diameter of 2.54 cm, and is located 37.6 cm below the surface of the mercury". The answer is 25.4 N
1) I have tried p=F/A ending with A*p=F or 2.54*136000=F (Wrong)
2) and F=phgA and again the number to big
3) Finally I tried P2=P1+pgh with P1=(1.01x10^-5) again too large of an answer
Am I missing something from try #1?
Thanks for any assistance
Your first attempt is wrong because you used the density in the formula for pressure! :eek: (it's ok...an honest mistake).
pressure (letter 'p'): force per unit area
[tex]p = \frac{F}{A}[/tex]
density (letter 'rho'): mass per unit volume
[tex]\rho = \frac{m}{V}[/tex]
I'm curious...where did you get the answer 25.4 N? Is it given in the book? Because it doesn't specify what the pressure is above the surface of the tank. Assuming it was atmospheric pressure, and using the third formula you tried, I got the wrong answer. But assuming it (p1) was zero, I got the following:
[tex]p_2 = 0 + \rho g h[/tex]
[tex]F = pA = (\rho g h)(\pi r^2)[/tex] = (13 600 kg/m3 )(9.81 N/kg)(0.376m)([itex]\pi[/itex])((0.0254m)/2)2 = 25.4 N
That's the right answer, but the method seems a little off...does the problem give more info about the pressure above the tank?
You solved it right, cepheid. Below the plug, there is atmospheric pressure too. So that, the force exerted by the atmosphere is canceled at the two sides.
  • · Replies 24 ·
  • · Replies 23 ·
