Integer solution to exponential diophantine equation
  • Context: Graduate
  • Thread starter Thread starter adoado
    Exponential Integer
The discussion centers on determining whether an integer C can be expressed in the form C = 2^A * 3^B, where A and B are integers. The solution involves checking the divisibility of C by 2 and 3, and if C contains any prime factors greater than 3, it cannot be expressed in the desired form. The method includes factorization of C and iterative division to find the values of A and B, concluding with a test to see if the remaining value of C equals one.
  • Understanding of prime factorization
  • Basic knowledge of integer properties
  • Familiarity with iterative algorithms
  • Ability to perform modular arithmetic
  • Study integer factorization techniques
  • Learn about modular arithmetic and its applications
  • Explore algorithms for prime factorization
  • Investigate computational methods for solving Diophantine equations
Mathematicians, computer scientists, and anyone interested in number theory, particularly those working with Diophantine equations and integer factorization.
adoado
Hey everyone!
I was recently scribbling on paper, and after a series of ideas, I got stuck with a problem. That is, can I find out if there exists some integers A and B such that
[itex]C=2^{A}3^{B}[/itex]
For some integer C?
For an arbitrary C, how do I know whether some [itex]A, B \in \textbf{Z}[/itex] exist?
Cheers for reading!
Adrian
Hi, Adrian,
it shouldn't be harder than testing if the number is divisible by 2 or by 3; and, in that case, if you are interested in the actual values of A and B, just divide and iterate. Unless you mean really big numbers.
Code:
Solving with a computer:
Factor C  givin a list of it's prime factors and their occurences;
if there i9s a factor > 3 then 'No, C is not of the required form'
else 'Yes, A and B are the number, the factor 2 (resp 3) occurs
Solving with paper and your head:
Set A and B to zero
Loop2:
If C is even replace C by C / 2 andd add 1 to A
   loop until C is odd
Loop3:
If C is multiple of 3 (add the digits modulo 3)
   replace C by C / 3 andd add 1 to B
   loop until C is not a multiple of 3
Test: it the remaining C is one, then 'Yes' else 'No'
