Calculate useful energy output ?
  • Context: Undergrad
  • Thread starter Thread starter Neil1985
    Energy Output
The discussion focuses on calculating the useful energy output of a hydraulic lifting frame system, specifically a third-order lever. Given an input work of 3000J, the calculation reveals that the load force (Fload) can be determined using the formula Fload = Feffort * (dload/deffort). By substituting the distances (5M for load and 1M for effort), the useful energy output is calculated to be 500J, enabling the lifting of masses up to approximately 50kg.
  • Understanding of hydraulic systems and their mechanics
  • Familiarity with the concept of levers, specifically third-order levers
  • Knowledge of work-energy principles in physics
  • Ability to perform basic algebraic calculations involving force and distance
  • Study the principles of hydraulic systems and their applications
  • Learn about the mechanics of different types of levers and their efficiency
  • Explore the work-energy theorem and its implications in mechanical systems
  • Investigate real-world applications of hydraulic lifting systems in engineering
This discussion is beneficial for mechanical engineers, physics students, and anyone involved in designing or analyzing hydraulic lifting systems and their energy efficiency.
Neil1985
I have a problem i am trying to solve, the question is;
Calculate the velocity ratio for this system. If the work put in is 3000J, calculate the useful energy output.
The system in question is a Hydraulic lifting frame upon which crates are placed.
It is lifted with a hydraulic ram which is located between the load and the fulcrum, thus making this system the third order of lever.
The distance from the load to the effort is 5M and the distance from the effort to the fulcrum is 1M.
LOAD--------(5M)------I---(1M)---o (pivot)
I = Hydraulic ram.
(i apologize for the poor diagram!) Thank you in advance for any help.
I = Hydraulic ram.
Using Feffort = Fload * dload/deffort and solving for Fload we get Fload = Feffort * de/dl
and subbing in the distances and applied (effort) force we get
Fload = 3000J * 1/6 = 500J so you be able to lift masses up to about 50kg
  • · Replies 138 ·
9K
  • · Replies 24 ·
12K
  • · Replies 16 ·
