| New Reply |
Spherical Aberrations |
Share Thread | Thread Tools |
| Sep28-11, 04:12 PM | #1 |
A collimated light beam is incident on the plane side of a of index 1.5, diameter 50mm, and radius 40mm. Find the . 2. Relevant equations Refraction in a plane surface: [tex]s'=\frac{-n_2}{n_1}s[/tex] Refraction on a spherical surface: [tex]\frac{n_1}{s}+\frac{n_2}{s'}=\frac{n_2-n_1}{R}[/tex] Spherical Wave Aberrations: [tex]a(Q)= \frac{h^4}{8} \left[ \frac{n_1}{s} \left( \frac{1}{s}+\frac{1}{R}\right)^2 + \frac{n_1}{s'} \left( \frac{1}{s'}-\frac{1}{R}\right)^2 \right][/tex] R=Radius of curvature s=Object distance s'=Image distance n=index of refraction 3. The attempt at a solution So the light is traveling in a straight beam incident on the plane surface. By equation 1, the image distance is virtual and at infinity. so [itex]s'=-\infty mm[/itex]. I then use this value for the calculation of the image of a spherical surface using equation 2. Plugging everything in, I get a distance of 80mm. So s'=80mm. I then used equation 3 to get the spherical wave aberration and used a height of 25mm since the lens is 50mm in diameter. (Also, R<0 since it is a concave surface from left to right.) I got an aberration of -1.29mm. The book says the correct answer is -0.858mm. What am I doing wrong? :(? EDIT: Figured it out! I used 1.5 for the index in equation 3 instead of 1. |
| New Reply |
| Thread Tools | |
Similar Threads for: Spherical Aberrations
| Vector Spherical harmonics/spherical coordinates question | General Physics | 0 | ||
| Lasers - cavity stability, beam quality and aberrations... | General Physics | 1 | ||
| Optics - why chromatic aberrations | Classical Physics | 15 | ||
| Help on optical aberrations needed | General Physics | 4 | ||
| Lens Aberrations | General Physics | 3 | ||
