How can we solve for (x+y)^4 = x^4+y^4 without using x=-y as a solution?
  • Context: Undergrad
  • Thread starter Thread starter JasonRox
The discussion revolves around the equation (x+y)4 = x4 + y4 and seeks to explore solutions beyond the case where x = -y. Participants are examining the algebraic manipulation and potential solutions, considering both theoretical and mathematical reasoning.
  • One participant notes that the equation holds true when either x or y equals zero and seeks other possibilities.
  • Another suggests expanding the left-hand side (LHS) and canceling common terms with the right-hand side (RHS), leading to a quadratic equation that purportedly has no real solutions.
  • A participant questions the validity of x = -y as a solution and provides an analysis showing that substituting x = -y leads to the conclusion that either x or y must be zero.
  • Further expansion of the LHS leads to a factorization that again suggests x = y = 0 is a solution, with a quadratic that appears to have no real solutions.
  • One participant retracts their earlier consideration of x = -y, indicating a potential misunderstanding of the problem.
Participants do not reach a consensus on alternative solutions to the equation beyond the case where x or y equals zero. Multiple competing views and analyses are presented, but no definitive agreement is established.
The discussion includes various algebraic manipulations and assumptions about the nature of the solutions, but limitations in the reasoning and potential missing steps are acknowledged without resolution.
JasonRox
[tex](x+y)^4=x^4+y^4[/tex]
We know this is true if x and/or y = 0, but what other possibilities are there?
I solved for (x+y)^2=x^2+y^2, which has x=-y as a possibility.
The solution isn't necessary, a couple tips should lead me in the right direction.
I broke it down in several ways, but a hint for something to look for would be great. I happen to always be stuck with something along the line like...
STUFF+x^2y^2
I can get the stuff area to equal to zero, but because the are both odd or even numbers that are equal I am always stuff with the odd one at the end.
I lost my paper that shows what STUFF is (stupid I know), but I'll work out a second time and maybe then I'll find a solution.
Any advice would be great.
Thanks.
Mathematics news on Phys.org
Expand the LHS, and cancel off the common terms with the RHS. You have 3 remaining terms =0. Factoring out xy (stipulating that they be not zero) from these gives you a quadratic, which has no real solutions, and this, you'll figure when you get to it...
Are u sure?
Substitute x=-y on the LHS and then in the RHS .. are they equal?
Simple analysis ,
(x+y)^2 = x^2+2xy+y^2
if (x+y)^2=x^2+y^2
implies
x^2+2xy+y^2 = x^2+y^2
implies
2xy = 0
implies
x or y or both = 0
A similar analysis has been outlined by Gokul in his last post for the power 4 case.
-- AI
(x+y)4= x4+ 4x3y+6x2y2+4xy3+ y4.
Setting that equal to x4+ y4, we can cancel the x4 and y4 terms on both sides leaving
4x3y+ 6x2y2+ 4xy3= 0 or
2xy(2x2+ 3xy+ 2y2)= 0
Clearly x= y= 0 works. It should be evident that 2x2+ 3xy+ 2y2= 0 has no real solutions so x= y= 0 is again the only solution.
Nevermind about x=-y. I was looking at the wrong solution.
  • · Replies 19 ·
