Time-Like Intervals: Can't Find an Inertial Frame for Events?
  • Context: Graduate
  • Thread starter Thread starter Master J
    intervals
The discussion revolves around the implications of time-like intervals in the context of special relativity, specifically addressing the inability to find an inertial reference frame where two time-like events occur simultaneously or in reverse order. The scope includes theoretical considerations and mathematical reasoning related to Lorentz transformations and the nature of time in physics.
  • Some participants assert that for a time-like interval, it is impossible to find an inertial reference frame where two events occur at the same time, as indicated by the space-time interval equation s² = c²t² - l².
  • Others argue that a Lorentz transformation cannot change the sign of the time component of the interval, which is crucial for understanding the ordering of events.
  • One participant elaborates that no valid state of motion can reverse the order of time-like events, as Lorentz transformations preserve the time direction.
  • Another participant notes that while local transformations cannot change a time-like interval to a space-like one, a global coordinate transformation can reverse time, but this does not alter the underlying physics.
  • There is a discussion about the implications of time symmetry in classical laws of interaction and how entropy growth relates to the experienced direction of time.
Participants generally agree on the properties of time-like intervals and the limitations of Lorentz transformations, but there are differing interpretations regarding the implications of reversing time and the nature of physical laws under such transformations.
Limitations include the dependence on the definitions of time-like and space-like intervals, as well as the unresolved implications of global time reversal on physical systems and entropy.
Master J
For a time-like interval between 2 events, it is impossible to find an inertial reference frame in which the events occur at the same time. This can be seen from the space-time interval s[itex]^{2}[/itex]=c[itex]^{2}[/itex]t[itex]^{2}[/itex]-l[itex]^{2}[/itex] where s must be real number for a time-like interval.
However, how does it follow from this that one cannot find a frame in which they occur in the reverse order?
Inertial reference frames have to be related by a Lorentz transformation, and a Lorentz transformation can't change the sign of the time component of the interval.
You can't find such a frame corresponding to any valid state of motion relative to the given events, that changes their order. This follows from the Lorentz transform - time is never reversed for any relative speed v. Further, no valid coordinate transform can change timelike to spacelike (this follows simply because all invariants are preserved under coordinate transform, esp. timelike interval).
However, you can do a global coordinate transform that reverses time. This effectively just 'runs the universe backwards'. All classical interaction laws are time symmetric. While this will be locally valid, in any realistic physical system, one of these time directions will match growth of entropy, while the other won't. We say that that the direction of entropy growth is the direction time is experienced.
But how does the sign of the time component matter, since time squared is in the interval?
Ah, so what I am gathering here is that for an event A with time component t, and another event B say at t=0, one cannot transform to another frame (with a Lorentz transformation) so that A is now at -t since the Lorentz transform cannot change the sign of t.
That makes sense! Cheers guys!
I thought both answers you've received explained that. Put any velocity you want, positive or negative, into the Lorentz transform, and it doesn't change time direction.
I also noted that you can globally reverse time coordinate, but that doesn't really change physics - you can tell you are looking at the universe run backwards (people will be expelled feet first from pools, to arc onto diving boards, etc.).
  • · Replies 35 ·
  • · Replies 141 ·
10K
  • · Replies 101 ·
  • · Replies 54 ·
  • · Replies 43 ·
