DIY - Thermoelectric Peltier Seebeck Thermocouple?
This discussion focuses on the construction of a DIY thermoelectric generator (TEG) using 400 copper and 400 steel wires, soldered together to create alternating thermoelectric junctions. The design involves a PVC pipe setup where the soldered joints and wires are exposed to temperature differentials to generate electricity. Key insights include the importance of maximizing the temperature difference for efficiency and the recommendation to use more effective materials than PVC for better thermal conductivity. Additionally, increasing the number of thermoelectric elements beyond 800 is advised to achieve a noticeable electrical output.
  • Understanding of thermoelectric generators (TEG) and thermoelectric effect
  • Basic knowledge of soldering techniques and materials
  • Familiarity with thermal conductivity and insulation principles
  • Knowledge of materials used in thermoelectric applications, such as bismuth telluride
  • Research advanced thermoelectric materials and their efficiencies
  • Explore the design and construction of Peltier modules
  • Investigate alternative materials for improved thermal conductivity in TEGs
  • Learn about optimizing temperature differentials in thermoelectric systems
This discussion is beneficial for DIY enthusiasts, engineers, and scientists interested in thermoelectric technology, energy recovery systems, and those looking to enhance their understanding of thermoelectric materials and their applications.
Are You Working on any Alternative Energy Projects?
  • Solar?
    Votes: 2 100.0%
  • Wind?
    Votes: 1 50.0%
  • Thermal?
    Votes: 1 50.0%
  • Static?
    Votes: 1 50.0%
  • Gas?
    Votes: 1 50.0%
  • NONE
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
whocouldshebe
I'm trying to build a DIY working model of TEG/TEC generator similar to the exhaust pipe designs that recover energy from extremely hot exhaust pipe or light those antique candle powered radios.
I have 400 (1 inch) pieces of copper wire and 400 (1 inch) pieces of paper clip steel wire. I will twist each one of each together then solder so that one end is copper with the other end steel having 400 pieces with a 1/4 inch solder joint in the middle.
I plan to then then take a large PVC pipe (4" only 1 end open, the bottom has a sealed cover, to make a cylinder bowl, insides paint with high temp flame resistant paint) and drill (or melt with soldering iron) 800 holes spiraling up the outside (closely spaced, like 1/4 inch apart to insert the copper/steel ends into from the inside so that the 1/4 inch solder point remains in the middle of the tube but not touching. I can then twist/solder each of the remaining 400 copper/steel wire connections together on the outside of the tube to create an alternating series of copper/steel twists with solder spiraling up on the outside as well as the inside.
I'll close off the each hole with high temp auto sealant glue from the outside and place the 4" PVC cylinder bowl into another 6" PVC cylinder bowl and fill the external surrounding cavity with ice to cool the external solder points. I can then place several candles in the middle cavity to heat the internal solder points sticking out in the middle and cover as necessary to trap the heat inside. I'm not expecting to get much power from the positive/negative terminals (maybe 200mV.)
The question I have is, which is better to be exposed to the hot/cold?
Is it the 400 soldered joints or the 800 alternating copper/steel wires?
Peltier modules look like steel cubes joined in a series alternating on the top and bottom by copper leads. Am I right in that they just 'look' deceiving, where the tops and bottoms are being joined by a 3rd soldered metal, and that the cubes are actually 2 different alternating types of metal? From what I can see that's what the diagrams show. If so then my design is correct, the soldered joint is supposed to be exposed to extreme temperature differentiation for better efficiency. Is this correct? Thanks.
Dear DIY scientist,
Thank you for sharing your project idea with us. It sounds like an interesting and challenging endeavor. I would like to offer some suggestions and considerations for your design.
Firstly, I would like to address your question about which part of the setup, the soldered joints or the alternating copper/steel wires, should be exposed to the hot/cold temperatures. In a TEG/TEC generator, the temperature difference between the two sides is what generates electricity. Therefore, it would be beneficial to have both the soldered joints and the alternating wires in contact with the hot and cold sources. This will increase the overall temperature difference and thus, the efficiency of your generator.
Secondly, I would like to mention that the efficiency of a TEG/TEC generator depends on several factors such as the temperature difference, the size and material of the thermoelectric elements, and the thermal conductivity of the materials used. In your design, using PVC pipes and ice may not provide a significant temperature difference to generate a substantial amount of electricity. I would recommend using more efficient materials such as aluminum or copper for the pipes and a better thermal insulator for the cold side.
Additionally, the number of thermoelectric elements used also plays a crucial role in the efficiency of the generator. From your description, it seems like you are planning to use 800 elements, which may be too few to generate a significant amount of electricity. I would suggest increasing the number of elements to at least a few thousand to see a noticeable output.
Finally, to address your question about the construction of Peltier modules, you are correct that they are made up of two different types of semiconducting materials (usually bismuth telluride and antimony telluride) joined together by metal leads. The metal leads are used to connect the individual modules in series, and they are not exposed to the temperature difference in the same way as the semiconducting materials.
In conclusion, your design has some potential, but it may require some modifications and improvements to generate a significant amount of electricity. I would also recommend doing some research on the efficiency of thermoelectric materials and modules to get a better understanding of their capabilities and limitations. Good luck with your project!
  • · Replies 23 ·
  • · Replies 26 ·
