| Thread Closed |
Why 220@50hz and 120@60hz? |
Share Thread | Thread Tools |
| Nov22-04, 02:25 PM | #1 |
Why 220v@50hz and 120v@60hz?
Who came up with these and why are they different - especially the frequencies? I heard that when Tesla was around, someone wanted the frequency to be @330... why? |
| Nov23-04, 12:53 AM | #2 |
Recognitions:
After Tesla won the AC/DC fight with Edison he gained much influence and more or less dictated the 60Hz frequency in the US. I think he had an ulterior motive in that he wanted to transmit power without wires and had calculated the 60Hz frequency was best for that purpose. I have no idea why the European nations choose 50Hz, as it is less efficient to produce and transmit over wire than 60Hz. The best frequency for power transmission is probably moderately higher than 60Hz.
Consider above opinion not fact. |
| Nov23-04, 11:39 AM | #3 |
I suspect it was to do with how fast the old generators could spin before they flew apart.
If you compare the size and mass of a 10 killowatt aircraft generator or induction motor (which run at 400 Hz) with a 10 killowatt 50 or 60 Hz unit, you'll be left wondering why we're not using higher frequencies (the equivalent aircraft units are tiny). I suppose the frequency can't be too high for long distance transmission of power (there would be more losses), but I suspect it could easily be a lot higher than 60Hz. |
| Nov23-04, 10:07 PM | #4 |
from what i understand europe picked 50Hz because it was felt it be easier number to work with due to the metric system as for the voltage, that is what edison picked when he came up with dc
| Nov28-04, 06:33 PM | #5 |
LOL!
That's a horrible reason. :D |
| Nov28-04, 07:22 PM | #6 |
| Nov28-04, 07:59 PM | #7 |
Here is some information on the evolution of 50 Hz. It seems that a combination of the engine and generators used, the ideal engine speeds, the desired voltage, and the number of poles used in the generators drove the selection of frequency in a complex fashion. I doubt that any simple answer exists.
| Nov28-04, 08:09 PM | #8 |
There may be some places in the world that use 20 Hz. The old streetcar used 20 Hz. When they were taken out of service the power plants were sold to some cities in other countries. They were still in use about 20 years ago. I think the reason they used 20 Hz back then is that they used rotary rectifiers. The motor on the streetcar was DC.
| Dec4-04, 08:58 PM | #9 |
Up to the '40's the iron laminations of rotors and stators of electric motors and generating equipment were poor quality and hysteresis losses were a major factor. (note how large old electric motors are compared to newer ones). Higher frequencies would have worsened the losses so up 'till then 25 Hz was common in Canada and the US.
When better steel was used for laminations, north America changed to 60 Hz about 1950, the Europeans decided 50 Hz was the cat's meow. |
| Dec13-04, 03:46 PM | #10 |
I heard that the European used 50Hz becasue it apparently interefered with you heart less that 60Hz.
| Mar27-06, 01:55 PM | #11 |
I heard two different reasons for the US choosing 60Hz. One as mentioned above, the Europeans chose 50Hz because of better calculations with the Metric system. Likewise, the US chose 60Hz to better measure periodic voltage (60 minutes, 60 seconds).
The other, more 'Urban Legend' reason why the US choose 60Hz was in one of its first applications--The Electric Chair--it was determined that 60Hz was the optimum Frequency to Kill a human. This then became the standard. LIKE I SAID I HEARD THAT RECENTLY FROM AN MIT PHD Professor. Doesn't make that much sense though if you consider that same danger is being carried out to every home. |
| Mar28-06, 12:16 PM | #12 |
I once heard that the reason for 60 hertz is that is was the highest frequency you could get without developing standing waves on a trans-continental transmission line.
| Mar28-06, 09:41 PM | #13 |
Edison was desperate in his attempts to discredit Westinghouse's AC system and was resorting to all sorts of public relation propaganda to prove how dangerous it was (including the promotion of the electric chair). It was hardly to Westinghouse's (or Tesla, his top engineer that designed the modern 3 phase system) advantage to promote the "deadliness" of his product. |
| Apr19-06, 01:00 AM | #14 |
Not to dig up a dead thread but I read a biography on tesla 2 years ago and remember reading about the 50hz vs 60hz debate. Tesla intended his generators to be run at 60hz but the french operators (at the first ac generator in europe) didn't want to speed up their machines, or something the like. From that point on every one just followed suit and didn't question, untill now ;-)
| Apr20-06, 11:39 AM | #15 |
Which makes me question the 15 kV 16 2/3 Hz railroad power that seems to be adapted as a standard in many European countries. Do they use different generating stations than the regular 50 Hz, or do they do some complicated frequency change somewhere along the line?
And why 16 2/3 Hz? Something with the old locomotives? I doubt it matters much these days with the thyristor locos. |
| Apr21-06, 11:42 PM | #16 |
| Apr22-06, 09:21 AM | #17 |
Admin
When I was in Japan, I learned that east is 50 Hz and west 60Hz.
Eastern Japan 50 Hz (Tokyo, Kawasaki, Sapporo, Yokohama, and Sendai); Western Japan 60 Hz (Osaka, Kyoto, Kobe, Nagoya, Hiroshima) Basically, TEPCO (Tokyo Electric Power Co.) is the main supplier in east, and KEPCO (Kansai Electric Power Co.) is main supplier in west. http://en.wikipedia.org/wiki/List_of...nd_frequencies Regarding 220 V @ 50 Hz and 120 V @ 60 Hz, IIRC 220V is line-to-line voltage in a 3 phase system, and 120 V is line-to-neutral. This has to do with 'Y' vs [itex]\Delta[/itex] configuration. Several electrified railways used 25 Hz in US. http://en.wikipedia.org/wiki/Electrified_railways |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why 220@50hz and 120@60hz?
| What happens when you put inert electrodes @ 220V/50Hz in tap water? | Classical Physics | 6 | ||
| Maximum Amplitude, 50hx vs 60hz generator | Introductory Physics Homework | 0 | ||
| 60hz supply - effect on psu output? | Electrical Engineering | 1 | ||
| What do I need in order to use 110V 50Hz air condition to a place which has 220v 60Hz | Electrical Engineering | 2 | ||
