| New Reply |
Which programming language should I use? |
Share Thread | Thread Tools |
| Dec15-11, 08:31 AM | #18 |
Which programming language should I use?(2) TEXTSPEAK is not allowed. Say PLEASE, not "plz", and so forth. As to the useability of ANY language, it depends somewhat on what you are going to use it for. Your quesion needs to be expanded. |
| Dec15-11, 09:32 AM | #19 |
Recognitions:
If this is a non-standard extension to Fortran, it is a ridiculous way to create buggy code, unless the argument to ACOS is a complex expression. I don't have any problem with ACOS((2, 0)) returning a complex value, but ACOS(2) should give an "out of range" error, not a complex value that is then silently truncated back to a real value. |
| Dec15-11, 09:36 AM | #20 |
If you need a programming language for making calculations, you could use a program like Visual Basic, which will provide a lot of functions for you to use. If you're needing to make more complex calculations, you should use a language like C++.
For physics simulations, there are programming languages designed specifically for those. |
| Dec15-11, 11:29 AM | #21 |
Hello everyone. Sorry to jump in and ask this question.
I want to make complex calculations and plot it's graphs, should I use Matlab? Can Matlab perform complex mathematical calculations, like calculating expressions that contain inverse trigonometric functions(OP's actual question), logarithms, matrices, etc.? I know Matlab can create graphs. How about C++. I have not seen C++ make any graphs. Is it possible to plot graphs using Java/C/C++? Tell me your best language which can do things like complex mathematical calculations and plotting graphs and physics simulations, or just complex mathematical calculations and plotting graphs, in a single environment. If there's any thing like that. Thanks. |
| Dec15-11, 03:53 PM | #22 |
| Dec16-11, 12:20 AM | #23 |
| Dec16-11, 03:42 AM | #24 |
The way you typically plot graphs in MATLAB is to create row vectors corresponding to your variables (like x and y), and MATLAB provides a lot of routines to generate vectors with certain values (like say for your x-axis), and defining functions is also very easy for calculating your f(x) for example. If you want to use MATLAB, its a good idea to look up function handles, the linspace command, and the plot functions for what you have described above (functions and graphing). |
| Dec16-11, 09:29 AM | #25 |
"Okay. Can I even do complex mathematical calculations in Matlab along with plotting graphs of complex mathematical equations?"
![]() Example: Suppose I want to draw a graph for sec θ=x + 1/4x I want 'θ' on the y-axis and different values of 'x' on x-axis. Can I plot the graph? I am Sorry if I am going beyond the context of what should be asked in "Programming & Comp Sci" section. But if anyone here who is good at Matlab can explain me this. That would be great. Just want to know if it's possible to plot graph of complex mathematical functions after performing complex mathematical calculations(calculations involving Calculus, Algebra, Trigonometry, Probability), both done in the Matlab software. I will be doing Digital and Analog Signal Processing and Analysis. Purpose is to analyze signals/graph and generate random signals/graph. I don't want to switch softwares and languages after finding out that it's not useful for my purpose. I only know that Matlab can do things like recognition/detection. |
| Dec16-11, 09:40 AM | #26 |
Mentor
If you want to ask specifically about Matlab, the place to do it is the "Math & Science Software" forum:
http://www.physicsforums.com/forumdisplay.php?f=189 |
| Dec16-11, 10:03 AM | #27 |
For that matter, you can draw these graphs even in Microsoft Excel or Libre Office. |
| New Reply |
| Tags |
| java, language, programming, simulations |
| Thread Tools | |
Similar Threads for: Which programming language should I use?
| Which programming language is best? | Academic Guidance | 12 | ||
| Recommended programming language (and texts) for middle-school beginner programming | Programming & Comp Sci | 9 | ||
| Programming language | Programming & Comp Sci | 10 | ||
| Which programming language do you use? | Academic Guidance | 20 | ||
| Which programming language is the best ? | Programming & Comp Sci | 15 | ||
