Combining Yellow & Blue Pigments: What Color Results?
  • Thread starter Thread starter JSGandora
    Color
The discussion revolves around the color resulting from the combination of yellow and blue pigments. Participants explore the implications of pigment mixing and the definitions of primary colors in different contexts.
  • The original poster attempts to reason through the color mixing process, questioning whether the result should be black or white based on absorption and reflection properties of pigments. Others suggest reconsidering the definitions of primary colors in the context of pigments versus light.
Participants are actively engaging with the topic, with some providing insights into the ambiguity of color definitions in different contexts. There is no explicit consensus, but guidance has been offered regarding the potential confusion between traditional and printing color models.
There is mention of an answer key indicating green as the result, which raises questions about the assumptions made regarding the pigments involved. The discussion also highlights the ambiguity in color definitions encountered in educational contexts.
JSGandora
What color results when yellow and blue pigment are combined?
W=R+B+G
[URL]http://www.horrorseek.com/home/halloween/wolfstone/Lighting/colmix_Additive.gif[/URL]
Since yellow pigment absorbs all wavelengths except yellow, then adding another pigment will absorb all the blue pigments so shouldn't the resulting color be black?
Or if the pigments mean that it reflects yellow and blue, then I think the resulting color would be white.
However, the answer key says green. I don't understand why...there is no solution either.
  • images?q=tbn:ANd9GcRU9pcX4QrtrUuQpliWuX2k7BuwOCVumwfi5t4hTN7SjcXLDSP9P78XqV3F.jpg
Hi JSGandora! :smile:
You appear to have landed in the murky area what exactly is which color.
When you are talking about pigments, the primary colors are usually named "yellow", "red" and "blue", which is what we learned in primary school.
However, in the world of printing these colors are actually closer to "yellow", "magenta" and "cyan".
So I suspect that when you were asked to combine yellow and blue, you were really asked to combine yellow and cyan (which is sort of light blue).
In that case the resulting color would indeed be green.
Hm, that's quite ambiguous, considering that on a Science Olympiad Optics test. Thanks for the help! :)
Agreed! :smile:
Yep ... I've often been startled to find how frequent it is that folks do not realize how ambiguously defined such color issue sometimes are.
  • · Replies 207 ·
16K
  • · Replies 21 ·
