New Reply
Can fluids flow naturally from areas of lower pressure to areas of higher pressure?
Share Thread Thread Tools
Oct6-11, 01:59 PM   #1
I maintain that not only they can, but that observations illustrating the phenomena are common.
To keep the thread from fragmenting too badly, I should like to propose the following rules of discussion:
1) Liquids shall be limited to water and air.
2) Only natural flows may be offered. Nothing initiated, modified, or influenced by man or his works.
3) The flows must be unconstrained: no channels, pipes, or containers.
4) A flow from low pressure to high pressure shall be deemed to have occurred if the internal pressure (as measured by an imaginary manometer at the midpoint of the parcel of fluid) is higher at the finish of the flow than it was at the beginning.
5) Acceptable evidence shall consist of scientifically-accepted citations and/or compelling argument.
What are your thoughts?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Oct6-11, 02:03 PM   #2
Quote by klimatos View Post
This one might be problematic. Are there unconstrained geophysical flows?
Oct6-11, 02:23 PM   #3
Well it really depends what you mean by 'pressure' in the fluid.
However in principle it's simple to offer examples where fluid flows from lower pressure to higher, simply by exploiting the gravity head component of Bernoulli's equation.
go well
Oct6-11, 02:40 PM   #4
xts
Any atmospheric or ocean circulation where air/water descends. Gulfstream sinking in arctic seas. Föhn winds. High pressure weather area.
Oct6-11, 03:44 PM   #5
Recognitions:
Gold Membership Gold Member
As for 1): Did you mean FLUIDS shall be limited to water and air?
Oct6-11, 03:57 PM   #6
Recognitions:
Homework Helper Homework Help
Assuming by flow you mean velocity, then due to momentum, this can happen. Pressure gradients only result in accelerations or declerations, not instantaneous changes in velocity.
Oct6-11, 09:35 PM   #7
Quote by Bobbywhy View Post
Of course, my stupid!
Oct6-11, 09:35 PM   #8
An excellent example of fluids flowing against the pressure gradient may be found in the field of limnology. In those parts of the world where lakes freeze over in the winter, the phenomena of spring and fall overturn occurs.
In the Fall, surface waters cool until the temperature of maximum water density occurs (about 3.94°C). At that time, portions of the surface water will sink through the underlying water until they reach the lake bottom. During that passage, the parcels of water move steadily against the pressure gradient. The pressure at the midpoint of the parcel when it reaches the bottom is substantially higher than when it started at the surface. Hence, there has been a natural flow of water against the pressure gradient.
This process repeats itself in the Spring.
New Reply
Thread Tools
Similar Threads for: Can fluids flow naturally from areas of lower pressure to areas of higher pressure?
Thread Forum Replies
Fluids: calculate pressure loss due to turns in pipe flow Mechanical Engineering 9
fluid mechanics bernoullis equation given inly two areas & the difference in pressure Engineering, Comp Sci, & Technology Homework 7
faster fluids have a lower pressure? General Physics 20
Fluid Dynamics Question: A glass tube... areas, pressure, determine height. Introductory Physics Homework 0
Pressure in an Accumulator? When the System Pressure/Flow is varying Sinusoidally Engineering Systems & Design 7
