Series-Parallel-Series Circuits
  • Thread starter Thread starter Monkey69
    Circuits
The discussion focuses on calculating currents and potential differences in a series-parallel circuit involving a 12V DC battery, a 100 Ohm resistor (R1), and three parallel resistors (R2: 120 Ohms, R3: 90 Ohms, R4: 160 Ohms) leading to a 210 Ohm resistor (R5). Participants recommend using Ohm's Law (V=IR) for basic calculations and suggest applying Kirchhoff's Current Law (KCL) for more complex circuits. The goal is to determine the expected currents at ammeters positioned at R1, R2, R3, and R4.
  • Understanding of Ohm's Law (V=IR)
  • Knowledge of Kirchhoff's Current Law (KCL)
  • Familiarity with series and parallel resistor combinations
  • Basic circuit analysis skills
  • Learn how to calculate equivalent resistance for parallel resistors
  • Study Kirchhoff's Voltage Law (KVL) for comprehensive circuit analysis
  • Practice solving simultaneous equations for current and voltage in circuits
  • Explore circuit simulation tools like LTspice for visualizing circuit behavior
Students in electronic engineering, circuit designers, and anyone looking to enhance their understanding of series-parallel circuits and electrical analysis techniques.
Monkey69
Hi Everyone. This is my first post on here. I'm currently doing an Electronic Engineering Diploma, but am struggling with just one thing (so far). Circuits and their equations. Everyone in that class are struggling, and I feel it may have something to do with the lecturers technique.
Anyway, as part of our first assignment, we need to work out expected currents in ammeters, and potential differences across resistors. I can't attach a drawing for this, but will attempt to explain.
I won't use the figures I have, as I'd like advice on the equations and mathematics that I need so that I can walk through it with my figures after.
We have a DC battery (12V) going to R1 (100 Ohms). This then goes to three parallel resistors, R2-R4 (120 Ohms, 90 Ohms and 160 Ohms respectively). These then all lead to R5 (210 Ohms).
The Ammeters are positioned at R1, R2, R3, and R4.
There's another one that's a bit more complicated, but hopefully with some easy to understand advice on this one, I should be able to figure that one out.
Anyway, any help would be greatly appreciated, and anyone who is able to explain this to me will forever go down as an absolute legend.
Thanks in advance.
Thanks in advance.
Welcome to the PF.
For really simple questions, you can just use Ohm's Law, V=IR to figure out voltages and currents.
And in some simpler resistor network questions, you can do series and parallel combination of resistors to simplify the network and help you solve it with just V=IR again.
For more complicated circuits, you would usually use Kirchoff's Current Law (KCL) equations written for all of the nodes in the circuit, and then you just solve the simultaneous equations to get the currents and voltages in the circuit.
So can you use this information to show us your circuit and show us how you are going to approach solving it?
Three resistors in parallel? I wonder how many ohms that would be equivalent to ...
