New Reply
Solve for charge(q), given radius, electric field, and density
Share Thread Thread Tools
Oct7-11, 09:18 PM   #1
In Millikan's experiment, an oil drop of radius 1.73 μm and density 0.865 g/cm3 is suspended in chamber C when a downward electric field of 1.44 × 105 N/C is applied. Find the charge on the drop, in terms of e. (Tolerance of solution is +/- 2%)
Known:
radius, r = 1.73 μm x 10-6 m
density, σ = 0.865 x 103 kg/m3
Electric field, E = 1.44 × 105 N/C
magnitude of charge of electron, e = 1.6 x 10-19
gravitational constant, g = 9.8 m/s2
2. Relevant equations
1. Force due to electric field: F = -qE
2. Mass of the drop, m = (4pi/3)*r3
3. Force of gravity, F = mg = (4/3)*pi*r3*σ*g
3. The attempt at a solution
(1) I rearranged equations (1) & (3) from above to solve for q, thus:
q = (-4*pi*r3*σ*g)/3E
(2) I then plugged in the given values:
q = [-4*pi*(1.73 x 10-6m)3*0.865 x 103 kg/m3*9.8 m/s2]/(3*1.44 x 105 N/C)
= -1.28 x 10-18 C
(3) Now, to put the solution in terms of e, I divided my result from (2) by the magnitude of charge of electron, e:
q = (-1.28 x 10-18 C/1.6 x 10-19 C)(1e)
= -8e C
However, my answer is incorrect, and I'm not sure why. I also tried to reverse the sign of my solution, but that was incorrect as well.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct7-11, 11:59 PM   #2
using the data I am getting
[tex]q=-3.83\times 10^{-18}\;\mathrm{C}[/tex]
check math
Oct9-11, 02:58 PM   #3
I checked the math again, and it turns out that the correct result was just -8, instead of -8e. Thank you for your reply, issac.
New Reply
Thread Tools
Similar Threads for: Solve for charge(q), given radius, electric field, and density
Thread Forum Replies
Model semiconductor -> calculate charge density, electric field, electric potential Advanced Physics Homework 0
Charge density and electric field Advanced Physics Homework 2
Electric field of uniform charge density Classical Physics 4
Electric Field and Charge Density Introductory Physics Homework 10
