Two fairly simple, but unrelated queries.
  • Thread starter Thread starter Bashyboy
Electrolytic solutions require the presence of ions to be conductive, typically achieved by dissolving ionic compounds. However, non-ionic substances like hydrochloric acid can also act as strong electrolytes upon dissolution. The term "changes phase" in the context of solutes refers to the transformation of a solute from solid to liquid when dissolved in a solvent, although certain mixtures, such as ionic liquids with water, may not exhibit a phase change.
  • Understanding of electrolytic solutions and conductivity
  • Knowledge of ionic and non-ionic compounds
  • Familiarity with phase changes in chemistry
  • Basic principles of solubility and dissolution
  • Research the properties of electrolytes and their role in conductivity
  • Study the behavior of non-ionic compounds in solution
  • Explore phase changes of solutes in various solvents
  • Investigate the chemistry of hydrochloric acid and its applications
Chemistry students, educators, and professionals interested in the properties of electrolytic solutions and phase behavior of solutes.
Bashyboy
Hi,
First, I was wondering, can electrolytic solution only be produced if its solute is an ionic compound? And, secondly, on one of my chemistry professors power points, he has written on it, regarding solutes, "changes phase (if different from solvent." Does he mean that it changes phase--the solute--when dissolved in the solvent?
Thank you
Chemistry news on Phys.org
Solution must be conductive, that means ions must be present. In most cases that means you need to dissolve some ionic substance. However, there are examples of non ionic substances that will do the same. Hydrochloride - as a gas - is not ionic, the bond is covalent, yet upon dissolution it becomes a strong electrolyte.
I am not sure I understand your question - yes, "changes phase" means "changes phase". I bet he means solid is no longer solid after dissolution, but if you mix ionic liquid with water there is no phase change.
  • · Replies 19 ·
11K
  • · Replies 20 ·
