What could be causing issues with Green's Theorem?
  • Context: Undergrad
  • Thread starter Thread starter Chronocidal Guy
    Theorem
The discussion centers on troubleshooting issues with Green's Theorem, particularly in the context of integrating a function over a closed curve. The user reports consistently obtaining zero when integrating along the sides of a square, despite successful double integrals over the area. Key factors identified include the necessity of correct normal vector orientation following the right-hand rule, ensuring the function F is continuous and differentiable across the region, and verifying calculations for accuracy. These elements are critical for correctly applying Green's Theorem.
  • Understanding of Green's Theorem and its applications
  • Knowledge of vector calculus, specifically normal vectors
  • Familiarity with double integrals and limits of integration
  • Concepts of continuity and differentiability in functions
  • Review the right-hand rule for determining normal vector orientation
  • Study the conditions for applying Green's Theorem, focusing on function continuity
  • Practice evaluating double integrals with various functions and regions
  • Consult resources on common pitfalls in vector calculus and Green's Theorem
Students and educators in mathematics, particularly those studying vector calculus and Green's Theorem, as well as anyone seeking to deepen their understanding of integration techniques in multivariable calculus.
Chronocidal Guy
Questions about Green's Theorem
When asked to demonstrate that Green's Theorem works, I keep coming up with disagreeing answers. I've been able to do the double integrals for the area of a region over a function F just fine, but whenever I try to integrate the same function over the closed curve using the normal vector, I keep getting zero... Say, I was integrating a function over a square. The double integral over the area works out just fine, but when I break the curve up into 4 sides, and try integrating each of those, I keep getting zero, because the opposite sides of the square cancel each other out. I don't really know what I'm missing, and it's been driving me nuts. Is there anything obvious that I'm just missing somehow?
yeah, the function has different values on opposite sides of the square so why should they cancel?
There could be a few reasons why you are encountering problems with Green's Theorem. One possible issue could be that you are not using the correct orientation for the normal vector when integrating over the closed curve. The orientation of the normal vector should follow the right-hand rule, where your fingers curl in the direction of the curve and your thumb points in the direction of the normal vector. If you are not using the correct orientation, it could result in the opposite sides of the square canceling each other out.
Another potential issue could be that your function F is not continuous or differentiable over the entire region. Green's Theorem only applies to smooth functions, so if your function has any discontinuities or sharp corners, it may not work.
It's also possible that there could be a mistake in your calculations. Double check your work and make sure you are using the correct limits of integration and properly evaluating the integrals.
If you are still having trouble, it might be helpful to seek out a tutor or consult with your professor for further clarification on the concept. Sometimes having a fresh perspective can help identify any mistakes or misunderstandings. Don't get discouraged, Green's Theorem can be a tricky concept to grasp, but with practice and persistence, you will eventually get the hang of it.
  • · Replies 20 ·
