Register to reply
What magnitude of force must the worker apply?
by blackandyello
Tags: friction, work
Share this thread:
blackandyello
#1
Oct10-11, 04:13 AM
P: 11
A factory worker pushes a 30.0-kg crate a distance of 4.5. along a level floor at constant speed by pushing horizontally on it. The coefficient of kinetic friction between the crate and the floor is 0.25. (a) What magnitude of force must the worker apply?
2. Relevant equations
summation of F x forces = 0
frictional force = coefficient of fric * normal force
3. The attempt at a solution
Hello, my solution is this
since the frictional force and the force of the worker in the x direction are equal,
fric force = 0.25 * 9.8 * 30 kg
fric force = 73.5 NEWTONS
so to find the magnitude of the force that the worker apply, we simply use trigonometric ratios.
cos (30) = 73.5 / r
r = 84.87 newtons
my answer is 84.87, but the answer in the book is 99.2 newtons. can you tell me where did i go wrong? tnx
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
georgir
#2
Oct10-11, 06:52 AM
P: 133
why cos(30) ? you never mentioned in your formulation of the problem that there are any angles other than 90 degree.
blackandyello
#3
Oct12-11, 08:53 AM
P: 11
Hello, im referreing to question 6.4a, (the one in black pen)
http://i55.tinypic.com/2e2md0z.jpg
tnx. ive tried my best but where did i go wrong? whats ur answer?
Redbelly98
#4
Oct12-11, 09:07 AM
Mentor
Redbelly98's Avatar
P: 12,069
Quote Quote by blackandyello View Post
cos (30) = 73.5 / r
r = 84.87 newtons
This is confusing because you posted Question 6.3(a), but show your work for 6.4 which is different because of the 30 degree downward angle of the worker's force.
The normal force is not simply the weight of the crate here. To work through a problem like this, you need to:
1. Draw a diagram showing all forces on the crate. Remember that the force from the worker is at an angle, not along the horizontal as it was in problem 6.3.
2. Set up two equations, using ƩFx=0 and ƩFy=0. Remember to separate the worker's force into components using sin and cos.
See if you can at least get that far, and if you're still stuck then post your work here for us to look at.
georgir
#5
Oct12-11, 09:53 AM
P: 133
Indeed, when the worker is pushing downwards, he is increasing the weight of the crate and so the friction force as well.
Register to reply
Related Discussions
Apply a force so it won't move? Introductory Physics Homework 4
Is it possible to have distance but apply no force? General Physics 5
[Problem]: Magnitude/direction of magnetic force, electric force and the net force. Introductory Physics Homework 5
What happens when you apply a force in space over infinite time? Special & General Relativity 14
How to calculate the magnitude of force when some force is applied at far away distan Mechanical Engineering 1
