Internal Resistance in a Battery
The discussion centers on calculating the internal resistance of a battery using two different current scenarios. When a current of I_1 flows, the potential difference is V_1, and when the current reverses to I_2, the potential difference becomes V_2. The equations derived are V = V_1 + I_1 * R and V2 - V = I_2 * R, where V represents the battery's real voltage and R is the internal resistance. The approach involves solving these equations to find the internal resistance accurately.
  • Understanding of Ohm's Law
  • Familiarity with electrical circuit concepts
  • Knowledge of voltage, current, and resistance relationships
  • Basic algebra for solving equations
  • Study the concept of internal resistance in batteries
  • Learn about the effects of temperature on battery performance
  • Explore advanced battery modeling techniques
  • Investigate methods for measuring internal resistance in real-world applications
Electrical engineers, battery researchers, and students studying electrochemistry will benefit from this discussion, particularly those focused on battery performance and internal resistance calculations.
joshanders_84
Hey I am confused as to the answer to this question; not sure exactly how to figure out what the answer is because it is not a constant resistance. Any help appreciated:
The potential difference across the terminals of a battery is V_1 when there is a current of I_1 in the battery from the negative to the positive terminal. When the current is I_2 in the reverse direction, the potential difference becomes V_2. What is the internal resistance of the battery?
I tried adding and subtracting the two resistances (R_1 = V_1/I_1 and R_2 = V_2/I_2), but that isn't correct, and I'm not sure of what to do. Thanks
Josh
Call the real voltage of the battery (when it's delivering no current) V, and its internal resistance R.
In the first case V = V_1 + I_1 * R
(Here, some of the battery's real voltage is wasted overcoming the internal resistance, so the measured voltage V_1 is less).
In the second case V2 - V = I_2 * R
(Here, the current is in the opposite direction, so both the battery's real voltage and it's internal resistance oppose the applied current).
So you have a pair of equations and a pair of unknowns. Should be easy...
correct, i get the same answer...
marlon
  • · Replies 16 ·
