| Thread Closed |
Basic Mechanical Properties of Carbon Nanotubes |
Share Thread | Thread Tools |
| Nov23-04, 06:03 PM | #1 |
I'm looking for information on the maximum possible strength of SWNTs.
What effect do thermodynamically inevitable(over macro scale lengths) lattice faults have on the tensile and compressive strength of the tubes? What effect does tube chirality and diameter have on tensile and compressive strength? What is the probability that composites will ever be as strong as single tubes? There is an undue level of contradictory information on them online for my taste. Thanks in advance for the help. |
| Nov24-04, 01:59 PM | #2 |
As carbon nanotubes are pretty much at the cutting edge of chemistry/materials science, that info is going to be hard to find. Have you tried looking in journal publications?
| Nov25-04, 10:44 AM | #3 |
Remember seeing somewhere that nanotube sheets had an axial elastic modulus of about/up to 1 TPa (in that case, would consider there to be some scatter(?)).
| Nov25-04, 05:57 PM | #4 |
to look up in the journals try... scholar.google.com
| Nov28-04, 03:42 PM | #5 |
What is scatter? |
| Nov28-04, 03:53 PM | #6 |
| Nov28-04, 05:01 PM | #7 |
| Nov29-04, 12:21 AM | #8 |
| Nov29-04, 04:28 PM | #9 |
How would I callculate how stiff a composite member of NTs could be? For example nylon makes nice strong flexible ropes but can also make hard plastic gears. Carbon fiber is flexible stringy stuff but put it in an epoxy and it's very light and stiff. Fiberglass same thing. What exactly is the Young's modulus if it's not the practical tensile strength? I'm not a mechanical engineer, just on a learning quest.
| Nov30-04, 12:47 AM | #10 |
http://physics.uwstout.edu/StatStr/s...ess/strs32.htm Its important not to mix structural stiffness and material stiffness. Like in your examples, if you simply take a large enough block of material of suitable geometry and apply a force to it, if the block is large enough, it is bound to have some stiffness (resistance to the applied force). If you have a case like above where you essentially have a composite of two or more materials, a simple way to derive condensed ("homogenized") material properties is often the rule of mixtures, used quite a bit in composite stuff for one (like when you got fiberglass fibres mixed to a plastic matrix): http://islnotes.cps.msu.edu/trp/back/est_rule.html http://www.matter.org.uk/glossary/detail.asp?dbid=341 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Basic Mechanical Properties of Carbon Nanotubes
| [SOLVED] Carbon Nanotubes | Chemistry | 4 | ||
| carbon nanotubes | Quantum Physics | 4 | ||
| Interlocking Carbon Nanotubes | Materials & Chemical Engineering | 11 | ||
| Carbon Nanotubes | Electrical Engineering | 0 | ||
| Carbon Nanotubes | Materials & Chemical Engineering | 3 | ||
