How to Calculate Volumetric Flow Rate from Pressure Change in a Chamber?
  • Context: Undergrad
  • Thread starter Thread starter wadswwc
    Flow Pipe
The discussion focuses on calculating the volumetric flow rate from a pressure change in a chamber containing air. The initial pressure (P0) is 11 psi, and the final pressure (P1) is 6 psi, with a change in time of 0.25 seconds and a chamber volume of 0.01 m³ at a temperature of 277K. The Darcy-Weisbach equation is recommended for analyzing fluid flow in this scenario, providing a foundational approach to derive the volumetric flow rate based on the given parameters.
  • Understanding of the Darcy-Weisbach equation
  • Knowledge of fluid dynamics principles
  • Familiarity with pressure measurement units (psi)
  • Basic thermodynamics related to gas behavior
  • Study the Darcy-Weisbach equation and its application in fluid flow analysis
  • Research the ideal gas law to understand air behavior under pressure changes
  • Learn about volumetric flow rate calculations in compressible fluids
  • Explore pressure drop calculations in pipes and chambers
Engineers, physicists, and students involved in fluid dynamics, particularly those working with gas flow in chambers and pressure systems.
wadswwc
Hey so I am trying to calculate the following scenario.
I have a chamber that must change in pressure at a certain amount of time. I need to find the volumetric flow rate coming out of the chamber.
Here is the info I have
P0=11psi, P1 = 6psi
Change in time = .25s
Fluid = air
Temperature = 277K
Volume of chamber = .01m3
I don't need an answer I just need direction, what equations to use, what additional info I need.
Any help is much appreciated.
Thanks,
Trae
Science news on Phys.org
  • · Replies 19 ·
