| Thread Closed |
Do high power microwaves ionise water molecules and/or rearrange food molecules? |
Share Thread | Thread Tools |
| Oct12-11, 08:39 PM | #1 |
Ok, this is a separate topic about Microwaves.
I have come across claim that microwaved food is safe for health as long as the food is microwaved on a low power. This is because microwaves oven that are used on high power can strip ionise a water molecule and rearraange atoms in food, which changes their molecular structure. If this is so, then should we not only use microwaves on low power ONLY? Regards student_ |
| Oct12-11, 08:48 PM | #2 |
Let me ask: Are you willing to give up on grilled food and fried food? If not, any worries about microwaves are absurd. The tendency of the former to create carcinogens is well established. The tendency of the latter to create harmful chemicals in actual cooking has never been established.
FYI: I have no intention of giving up grilled food, or microwave food. |
| Oct12-11, 08:56 PM | #3 |
PAllen has a good point. All cooking will cause chemical reactions in food. That's kinda the point. But they aren't very discriminate about it.
For example, any time you burn something (like in an oven, stovetop or BBQ), you are creating PAHs (poly aromatic hydrocarbons), which are known carcinogens. Very difficult to burn something in a microwave. |
| Oct12-11, 08:57 PM | #4 |
Recognitions:
| Oct12-11, 09:08 PM | #5 |
i would just say heat things slowly, especially if there is a lot of oil or fat. microwaves do not just heat water molecules. and unlike water, fats can have boiling temperatures much higher than 100C. i think this is much of the reason food that is "nuked" on high often tastes bad. it also can screw up your plastic containers.
i don't "cook" anything in a microwave, save popcorn. and what i reheat, i do slowly so that i do not overheat the fats, and the taste doesn't come out mangled. |
| Oct12-11, 09:14 PM | #6 |
| Oct12-11, 09:27 PM | #8 |
| Oct12-11, 09:39 PM | #9 |
In pyrex, porcelain or microwave safe ceramic containers, I've not had any problem with fats (taste or otherwise), but definitely avoid warming breads or pastries in microwave, purely due to adverse taste and texture. In a pinch, I do pizza slices, but the crust is always ruined in taste and texture. As for power, I use high to heat liquids, medium-high for most other food, low for defrosting. As for cooking, I think the only issue is flavor. Flame based cooking tastes better, but I suspect is more harmful than microwave cooking. There is only one Indian stew I currently cook in a microwave. |
| Oct12-11, 09:43 PM | #10 |
Note that the infrared and visible radiation from a red hot heating element in a conventional oven has more potential to ionize molecules in the food. Now if you put flecks of metal in the food and let them arc in the microwave you might get something going that way. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Do high power microwaves ionise water molecules and/or rearrange food molecules?
| Distance between water molecules. | Introductory Physics Homework | 2 | ||
| Water molecules | Atomic, Solid State, Comp. Physics | 1 | ||
| What causes the H bonds in water molecules to last only 10^-11 sec? | Biology, Chemistry & Other Homework | 1 | ||
| Acidic Water Molecules | Chemistry | 10 | ||
| does water molecules exist in KOH(aq)? | Biology, Chemistry & Other Homework | 1 | ||
