The electric field of two plates
The discussion revolves around the electric fields generated by two different plates: an aluminum plate and a glass plate, both with a uniform charge distribution. Participants are comparing the electric fields just above the centers of the upper surfaces of each plate, using Gauss' Law as a framework for their analysis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants present their calculations for the electric fields of both plates, questioning the definitions of surface charge density and the application of Gauss' Law. Some express uncertainty about the distribution of charge and its implications for the electric field.
The discussion is ongoing, with participants providing differing interpretations of the charge distribution and its effects on the electric fields. Some guidance has been offered regarding the definitions of surface charge density, but no consensus has been reached on the correct approach or final answers.
Participants are navigating the complexities of charge distribution on conductors and insulators, with references to specific physics texts and concepts. There is a focus on the implications of surface area and charge distribution in the context of Gauss' Law.
mborn
Another question for Gauss' Law;
A very large, thin, flat plate of Aluminium of area A has a total charge Q uniformly distributed over its surfaces. If the same charge is spread uniformly over the upper surface of an otherwise identical glass plate, compare the lectric fields just above the centers of the upper surface of each plate.
M B
Hi,
my answers are;
For Al [tex]E= \frac{\sigma}{\epsilon_o}[/tex]
for Glass [tex]E= \frac{\sigma}{2\epsilon_o}[/tex]
Someone tell me if I am wrong, please
hhegab said:
Hi,
my answers are;
What about Q and A?
The charge Q spreads out over both surfaces of the aluminum and there is 0 charge inside the metal. So [itex]\sigma = Q/2A[/itex]
The field of the Al sheet is [tex](E_{top} + E_{bot}) = \frac{Q/2A}{\epsilon_0}[/tex]
So: [tex]E_{top} = \frac{Q/2A}{2\epsilon_0}[/itex]<br /> <br /> For the glass plate, Q is distributed over area A (not 2A), so [itex]\sigma = Q/A[/itex]<br /> <br /> [tex]E_{top} = \frac{Q/A}{2\epsilon_0}[/itex]<br /> <br /> AM[/tex][/tex]
hhegab's right...though I wish he hadn't spilled the solution out.
AM, I believe you have it backwards. In both cases, the surface charge density is usually defined as [itex]\sigma = Q/A[/itex]
For Al :
[tex]\vec{E} = \vec{E1} + \vec{E2} = \sigma /2 \epsilon _0 + \sigma /2 \epsilon _0 = \sigma /\epsilon _0[/tex]
For glass, there's only the one charged surface.
For Al :
I am not sure what you are referring to as being backwards.
[itex]\sigma = Q/2A[/itex] for Aluminum since the charge is distributed over both surfaces of the sheet. For glass [itex]\sigma = Q/A[/itex] since, as you point out, there is only one charged surface of area A.
Just substitute these values for [itex]\sigma[/itex] into your equation to get my answers.
AM
Peace,
In Serway's Physics for S&E ,6th edition, chapter 24 section 4 (conducing surfaces), when using Gauss' Law
[tex]\oint{\vec{E} \cdot d\vec{A}} = \frac{Q_{enc}}{\epsilon_0}[/tex]
is used, we have A as the TOTAL surface area not a surface of a particular region on the material under study. This is how I reached my answer, what do you think?
hhegab
hhegab said:
Peace,
So what is your answer in terms of Q and A?
AM
[tex]\sigma = \frac{Q}{A}[/tex] in both cases;
hhegab
hhegab
So how does that occur if the surface charge density of the top surface of the alluminum conductor is the same as the bottom surface and there is 0 field in between the two surfaces?
AM
Peace!
The field lines are perpendicular to the surface, and directed either inward or outward according to the sign of sigma, when they added (vectirially) they will give a zero field.
Also, even in the presence of a field inside the conductor, when we put it an an external elecric field, the free charges will arrange themselves on its surface in such a configuration that after about 10^-16 sec. they will cancell the originl field.
hhegab
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 58 ·
