HELP:Volume generated( shell )
  • Thread starter Thread starter buffgilville
    Shell
The discussion focuses on calculating the volume generated by rotating the region bounded by the graph of f(x) = 4x² and H(x) = 4 around the line y = -1. The volume can be determined using the formula V = π∫(R(x))²dx, where R(x) represents the distance from the line y = -1 to the respective function. The solid formed in this case is classified as a "shell" due to its hollow center, which is a result of the specific rotation axis chosen. Pappus' Theorem is also referenced for finding volumes of solids of revolution.
  • Understanding of solid of revolution concepts
  • Familiarity with Pappus' Theorem
  • Knowledge of integral calculus
  • Ability to visualize geometric shapes formed by rotation
  • Study the application of Pappus' Theorem in volume calculations
  • Learn about the differences between shells, discs, and washers in solid geometry
  • Practice calculating volumes of solids of revolution using various rotation axes
  • Explore advanced integral calculus techniques for volume determination
Students and professionals in mathematics, particularly those studying calculus and geometry, as well as educators teaching solid geometry concepts.
buffgilville
HELP:Volume generated("shell")
Find the volume generated when the region bounded by the graph of
f(x) = 4x^2
and the graph of
H(x) = 4
is rotated around the line y = -1
How do I solve this? How do I know if, when rotated, if the solid form a "shell" or a disc, or a washer?
Use Pappus' Theorem to find the volumes for each function then compute the difference.
To find the volume generated, you can use the formula for volume of a solid of revolution: V = π∫(R(x))^2dx, where R(x) is the radius of the solid at a given x-value. In this case, R(x) would be the distance from the line y = -1 to the graph of f(x) or H(x), depending on which function is on top.
To determine if the solid formed is a "shell" or a disc or a washer, you can visualize the rotation and see what shape is formed. In this case, rotating around the line y = -1 will result in a "shell" shape, since the solid will have a hollow center. If you were rotating around a different line, you may get a disc or a washer shape instead. It is important to understand the concept of solid of revolution and how different rotation axes can result in different shapes.
  • · Replies 23 ·
  • · Replies 19 ·
