I have not used this concept too much, but I recall a little from reading kelley, general topology.
take any topological space X and any surjective map X-->Y to a set Y. then this map will be continuous with certain topologies on Y and not continuous with others.
i.e. the map is continuous iff every open set in Y ahs an open inverse image. so the more open sets Y has, the harder it is for the map to be continuous. E.g. if Y has the smallest possible topology, with only the empty set and Y open, the map is always continuous.
suppose we give Y the largest number of open sets, such that the map is still continuous. this i believe is called the quotient topology on Y.
i.e. given any surjective map X-->Y, we can view Y as made by taking a "quotient" of X by an equivalence relation.
just consider two points of X equivalent if they have the same image under the map.
Then given such a quotient space Y of X, the points of Y are actually subsets of X. Then the quotient topology on Y is expressed as follows: a set in Y is open iff the union in X of the subsets it consists of, is open in X.
This is a basic but simple notion. important, but nothing deep here except the idea of continuity, and the general idea of enhancing the structure of a set of equivalence classes.
the same thing goes on everywhere. given a group and a normal subgroup, one gets an
equivalence relation on the elements of the group and makes a group out of these classes.
given a ring and an ideal one makes a ring out of the quotient object.
in general quotient constructions are techniques for constructing "maximal" targets for surjective maps subject to a certain condition.
I'm sorry. you asked for a physical picture. imagine the real line mapping to the
circle by the map taking t to (cos(t),sin(t)). the "wrapping map" or polar coordinates map. then try to convince yourself that the quotient topology is exactly the usual topology on the circle.
