| Thread Closed |
the shock absorbing ability of steel |
Share Thread |
| Nov25-04, 02:22 PM | #1 |
can anyone explain the shock absorbing ability of steel? thank you
| Nov25-04, 02:30 PM | #2 |
Admin
Please elaborate - as in do you mean a steel spring (e.g. in a shock absorber) or do you mean something like a steel (or any strong metal) plate that absorbs/dissipates/deflects the shock wave of an explosive or impact of a missile?
| Nov25-04, 04:33 PM | #3 |
um.. actually, i want to talk about mild steel used in car bodies, because it has to be crash worthiness, so i think i better explain the shock absorbing property of that. is that related to the internal structure (the arrangment of the atoms) or the compositions that makes up mild steel?
| Nov26-04, 12:20 AM | #4 |
For protection of a car's occupants, my guess is that an exponentially collapsible structure with the greatest Young's Modulus for the least density would be optimal. Consider a honeycomb design with increasing wall thickness away from the impact.
You may wish to compare steel to carbon, in the form either of graphite or nanotubes. Another approach involves a bumper filled with water which, when compressed, jets out of apertures while approaching closely the critical pressure of solidification, thus using the near phase change to absorb the mechanical impact. |
| Nov26-04, 12:23 AM | #5 |
A bit of a general topic, in general we're talking about the ability of mild steels (and most steels overall as long as we don't go to really high strength ones etc.) to be able to plastically deform without fracturing. Under loading (static and dynamic, dynamic changes the response (a rate sensitive material) but not the principles that much) steels exhibit linear-elastic Hookean response followed by an elastic-plastic response, the linear region typically being defined up to strains of 0.2%, whilst the elastic plastic region can carry to several tens of percents (fracture strains are typically in the envelope of 10-70%) ... so, the elastic-plastic region is really extensive in terms of deformation, and I believe is what you call the ability to absord the shock. More than anything it is related to the mechanisms of plasticity in mild steels (i.e. what controls and affects the movement of dislocations, so to answer your question when we're comparing steels its a composion and treatment thing), and the configuration in mild steels is typically such that there ain't that many mechanisms impeding plastic deformation ... and since the amount of plastic deformation can be easily correlated to the energy the structure made of such steel can absorb, use of relatively low strength, "standard", steels becomes feasible (and due to the same elements they also strain harden quite a bit, another property which is quite essential in this application). I can probably find you a couple of links for further details .... ?
| Nov26-04, 01:26 AM | #6 |
Nice elaboration, perennialII. Toughness [an engineering thing] is the big issue in design. Toughness relates to plastic deformation and tensile strength. Steel is still very popular because it is very tough and cheap. Composite materials are, however, gaining ground. They are getting pretty tough and weigh less.
| Nov26-04, 06:32 AM | #7 |
PerennialII.. your explaination is good, but can u give me suggest some link related to that? coz i have to quote the website in my project.. thanks
| Nov26-04, 11:22 AM | #8 |
Admin
Just adding to what PerennialII already mentioned,
when I looked at stress-strain curves for mild steel, I found Young's (Elastic) Modulus of about 30 E6 psi, proportional limit of 0.00125, and strain at yield of about 0.0013-0.0014 (1.3-1.4%). The plastic range varies depending on composition, annealing/working, tempering, etc. The ideal material has strength, ductility (large deformation/strain between yield and failure), and toughness (resistance to fracture) under high loads and high strain rates - 1-10%/sec. Obviously the stresses are going to be above yield and perhaps locally above UTS. In addition to material properties (like composition, heat treatment), the designer will employ geometrical effects (tube wall/strip/shell) thickness and cross-section. Forward most the strip/tube wall thickness is reduced and thickness/cross section increases toward passenger compartment. The thinner sections collapse first. The passenger compartment has to be the strongest to resist deformation. This maybe helpful - http://www.a-sp.org/database/custom/...ult.asp?bid=18 A more general resource: http://www.autosteel.org/ulsab/index.htm http://www.autosteel.org/technical_i...4may_index.htm I was thinking that Society of Automotive Engineers (www.sae.org) would be helpful, but I could not readily find any basic info on automotive steels or mild steels. If you have a particular composition or grade, then try http://www.matweb.com/search/SearchSubcat.asp, or try a manufacturer/supplier website. Best wishes for success on your project. |
| Nov26-04, 12:15 PM | #9 |
Thanks ! I think Astronuc's text & links do a good job in explaining the case, especially the structural design details which are at least as important as the material when it comes to performance of the car body itself. And I'd say the point risen by Chronos goes to the heart of the matter (ductility, toughess, plastic design etc.). Couple of links on the somewhat theoretical side of things which hopefully will state what I did in a bit broader and general form :
http://www.engin.brown.edu/courses/En222/notes.htm http://jamaica.u.arizona.edu/ic/mse2...clocation.html http://www.mae.cornell.edu/zabaras/C...12/mae612.html http://ocw.mit.edu/NR/rdonlyres/Mech...24/0/lec10.pdf http://hotrodders.com/kb/body-exteri...eet_metal.html (the last one ... well, its a link at least). |
| Nov27-04, 08:24 PM | #10 |
whao.... thanks a lot for the links, they'r brilliant!!
but, i have a little question mild steel is one of low carbon steel which means not so strong when compared to high carbon one, why is mild steel used instead of high carbon steel? well, i was thinking whether the mild steel is heat treated first. but how can annealing change the crystal structure of mild steel? is it something related to the body centered cubic and face centered cubic thing? and from a steel website, they said heat treating of mild steel is process annealing, but they also said the process will soften the steel and improve machinability, it really confuses me, i thought annealing is gonna increase the hardness and strength of mild steel, but its seems to be differnet from what i thought its gonna be, can anyone clarify that, coz my teahcer will probably ask me to explain it. any help will be appreciated. |
| Nov28-04, 04:00 AM | #11 |
| Nov28-04, 10:28 AM | #12 |
PerenailII has covered the matter very nicely, but I'd like to add just one little thing here for ballball...
I think you may be confusing annealing with quenching. These two types of heat treatment usually result in diametrically opposite effects, the former raising ductility and toughness, while the latter raises strength and hardness (and of course, brittleness). Anyway, the heat treatment of steels is a huge topic by itself, and trying to make too many generalizations is ill-advised. |
| Nov28-04, 10:34 AM | #13 |
On a side note : strange as it may seem, some cast irons have very good vibration damping properties. I think they are called SG irons (because of spheroidal graphite nucleii), and get used in automobile cylinders, pump rotors and other places that can be a source of vibration.
| Nov28-04, 11:50 AM | #14 |
| Nov29-04, 03:43 AM | #15 |
What Gokul said is entirely appropriate. In stress relief you trade off hardness for ductility. Hardness increases resistance to catastrophic failure. Ductility trades off that resistance for yield strength. This is a very tricky thing in design engineering. Mechanical strength depends on geometry. Yield strength conserves geometry while permitting a bit of real world 'give' in design. For this reason, the more important factor in most design schemes is usually yield strength.
Footnote: Vibration is the curse of design considerations. Rigidity, while a good thing in principle, is a very bad thing when it comes to vibration. Fatigue is very strongly associated with rigidity and wear is very strongly associated with the lack of rigidity [hardness]. Optimizing the two is difficult. |
| Nov29-04, 08:19 PM | #16 |
Admin
A really good reference on carbon steels is ASM International's Specialty Handbook, "Carbon and Alloy Steels" http://www.asminternational.org/temp...roductID=10520
I have it and two companions "Stainless Steels" and "Heat Resistant Materials". But they are a bit pricey. Each of these costs $225 for non-members or $180 for members. The American Iron and Steel Institute (AISI) and Society of Automotive Engineers (SAE) have some good references as well. |
| Feb21-07, 01:14 PM | #17 |
Hello กกก
This is my very first post in this very great forum. I like to ask you If someone has idea of the high strenght high quality hardened and tempered steel response under the shock of high velocity projectiles with high hardness ogive (regarding striking velocities of around 500-1000 m/s and tip hardness of around 650-680 Brinell fardness) Thanks in advance to all and best regards
| Thread Closed |
Similar discussions for: the shock absorbing ability of steel
| Steel Block Rotating On A Steel Table | Introductory Physics Homework | 1 | ||
| Heat Absorbing Materials | Chemistry | 7 | ||
| Absorbing visible light! | Atomic, Solid State, Comp. Physics | 3 | ||
| absorbing photons | General Physics | 1 | ||
| Absorbing kinetic energy | General Physics | 7 | ||
